72 Cutlass grill paint
Old May 17, 2008 | 05:30 PM
Grumpy's Avatar
I have a 72 Cutlass and need to repaint the front grill. Can anyone tell me where to purchase the correct Grey color paint?
Old May 17, 2008 | 06:13 PM
dan1s's Avatar
Try fusick.com
I just got air cleaner paint from them and it was a perfect match. Great people to do business with.
Dan
Old May 18, 2008 | 05:25 AM
Grumpy's Avatar
Thanks Dan, I will give Fusick a try. Great looking 442. I'm new to the sight it looks really helpfull.
Bob
Old May 18, 2008 | 09:26 AM
Bluevista's Avatar
Registered
Everybody I know uses Krylon #1403 Dull Aluminum spray paint on the grills and tail light housings that color. It is hard to find, I ordered it from Ace Hardware online.
Allan
Old May 19, 2008 | 05:56 AM
dyscookn's Avatar
You can get these special paints from Eastwood.They are correct in color and texture.
Old May 21, 2008 | 04:02 PM
Grumpy's Avatar
72 Olds Grill
Allan
I took your advise and it came out great. Appreciate your input. Didn't have to much of a problem finding the paint, went to Ace and it was on the shelf.
Bob
Old May 21, 2008 | 05:16 PM
Bluevista's Avatar
Registered
Cool, Glad it worked out, that paint seems to be the hands-down favorite. I did my '71 grills and they came out really nice too, look like new. I tried everywhere around here and couldn't find that stuff, guys all over have the same problem finding it.
Allan
Old May 22, 2008 | 11:40 AM
Grumpy's Avatar
Paint
Allan
Could you or anyone tell me the correct color the head light beisel should be on a 72 Cutlass Supreme. Mine were painted black when the grill was painted black. I painted the grill the original color which looks good but the beisel don't look right in black. I'm thinking they should also be the same color as the grill. I do have a new set of chrome beisels the I think look good but want the original look for now.
Bob
Old Dec 9, 2019 | 06:59 PM
BrawnyMan's Avatar
Thanks to the advice in this thread I am glad with how my grille pieces came out for a ‘71Supreme. Any advice on painting the black in between the slots?
Old Dec 9, 2019 | 07:32 PM
There's a thread about this with lotsa details. I used a small model paint brush, which that takes a steady hand.
https://classicoldsmobile.com/forums...rilles-117279/
Old Dec 10, 2019 | 05:57 AM
scrappie's Avatar
Bob
If your talking about the headlight housing (plastic around headlights) on 72 it should match body color along with the stone shield (center plastic piece)
Old Dec 11, 2019 | 03:20 AM
chip-powell's Avatar
I also had to paint my grill this past spring. After botching the job a few years ago, I found a way to do it right. Paint pens. I could not find them in the stores, but go online and order a "Testers Flat Black" paint pen for metal. The only ones that I could find in the stores were gloss black.
I ordered 2 just in case the tip got damaged, but you will only need one. It has a slanted tip and an even flow of paint. If you can keep your hand steady, the slots will really pop and look great against the dull aluminum of the rest of the grill.
Old Jan 7, 2020 | 07:36 AM
BrawnyMan's Avatar
Got the grilles painted and spent quite a bit of time taping, cutting, and hand-painting the black paint in. Another question though; how do you attach the "Cutlass Supreme" emblem without breaking it? It seems more fragile than the original emblem. The original seems aluminum while the reproduction is definitely a plastic.
Old Jan 7, 2020 | 09:23 AM
It's actually fairly easy. Just be REALLY careful with the screw behind the final e in "supreme". That one is very touchy. On my 2nd attempt (I broke the 1st emblem) I held the "e" with my fingers while slowly screwing the nut on the back. Once I felt that cursive connector in front of the "e" start to move a little, I stopped tightening and left it be.
Old Jan 7, 2020 | 09:28 AM
70Post's Avatar
The factory used a black plastic backer plate that sits right under the emblem and helps support it. It may be repro'd. It's about 1/16" or so thick. You could fabricate one yourself if you can find some appropriate material.
Old Jan 7, 2020 | 10:14 AM
BrawnyMan's Avatar
I have that plate still, its the thread-cutting screw on the four prongs attached to the emblem that I am worried about.
Old Jan 7, 2020 | 10:16 AM
BrawnyMan's Avatar
Thank you! Did you use just a hand wrench with a little pressure?
Old Jan 8, 2020 | 02:40 AM
Use a hand wrench and just go by feel.
ilanzo
Jul 24, 2016 06:52 AM
70convert
Paint
May 3, 2014 03:50 PM
denf221
Jul 21, 2013 08:36 PM
CLcutlass
Paint
Oct 2, 2011 04:49 PM
gumbyssfakee
Paint
Aug 27, 2009 12:45 AM
