fast shifting
Old Oct 26, 2007 | 05:53 PM
GOLD72OLDS's Avatar
fast shifting
i have a 350 hydrotrans hooked to a 350 motor in a 72 cutlass supreme and by the time i get to 60 im all shift out it shifts real fast and drinks gas on tht interstate and if i mash the gas after 60 it doesnt kickdown for a quick acceleration is it broke or thats just how it goes ?
Old Oct 28, 2007 | 07:41 AM
Oldsguy's Avatar
Past Administrator
Well, you might be comparing modern cars with four speeds which have an overdrive to your '72. I think you should be in third gear by 60mph. It is possible your car has been modified by a previous owner and it may have a steeper rear end ratio which would cause what you precieve. Also, you mentioned the kickdown not working, is the linkage hooked up?
Old Oct 28, 2007 | 01:16 PM
GOLD72OLDS's Avatar
thanx for the help but im gonna need a lil more i dont know where to look for the linkage lol
Old Oct 31, 2007 | 04:35 PM
texasred's Avatar
Tom Servo's Stunt Double
See if this helps:
http://s122.photobucket.com/albums/o...=downshift.jpg
C.J.
Old Oct 31, 2007 | 05:11 PM
kevinkpk's Avatar
I'd look at what the engine is taching at if it's drinking gas, that would explain if the ratio has been changed, also not that familiar with turbo 350, turbo 400 does have a kick down solenoid. Could be if the 350 has the same (pretty sure it does) the solenoid could be bad or in my case the wiring on the plug was broken off.
Old Oct 31, 2007 | 05:34 PM
texasred's Avatar
Kevin,
The 350 has a cable. The link I posted is a picture of it and the adjustment procedure.
C.J.
B-Mann
Jul 23, 2009 11:39 AM
Matt15
Dec 20, 2008 05:15 PM
maskinen
Aug 17, 2008 11:29 AM
nohn
Jul 22, 2007 10:57 AM
<jdhideaway@aol.com>
Brakes/Hydraulic Systems
Mar 31, 2005 08:15 PM
