What wheel size to use?
Old Nov 24, 2008 | 06:30 PM
442 Guatemala's Avatar
Question What wheel size to use?
Hello I own a 69 442. Im going to buy new cragar wheels for the rear Im thinking on 15x10. the question is this size fit and what backspace and offset do I have to use. What tire size is recomended
thanks
Old Nov 25, 2008 | 04:58 AM
Oldsguy's Avatar
Past Administrator
I am not sure if a ten inch wheel will fit, I do know that tire with 10 inch tread will fit if it isn't too tall but usually the tires are wider than the wheel so......
Old Nov 25, 2008 | 06:43 AM
gearheads78's Avatar
car guy
thanks
Its been a while since I messed with that body style but I think a 10" with 5.5" back space on a 275-60 is what works. Its been over 10 years since I was in the wheel business so verify before you order.
Old Nov 25, 2008 | 07:29 AM
Oldsguy's Avatar
Past Administrator
Thanks for the help Richard.
Old Nov 25, 2008 | 08:47 AM
kaz442's Avatar
I'm running 15x10 with 5.5" BS on my '70 with 295-65-15 MTs. JKaz
Old Nov 25, 2008 | 09:49 AM
car guy
Sweet my memory is better than I thought.
Old Nov 25, 2008 | 10:10 AM
Thanks for the help, I think im going with 15x10 with 5.5 BS I allready have the 275-60-15 Tires. But the other question is the offset it has to Be 0???
Old Nov 25, 2008 | 10:29 AM
car guy
Offset is determined by BS. Just don't worry about offset.
Old Nov 25, 2008 | 10:35 AM
ok Thank again
Old Nov 25, 2008 | 12:08 PM
car guy
not a problem glad I could help
Old Nov 25, 2008 | 03:42 PM
I was going to jump all over you until I realized you meant backspacing... DOH!
And just for completeness, half the wheel width minus the backspacing equals offset. If the backspacing equals half the width, the offset is zero.
Old Nov 25, 2008 | 04:09 PM
car guy
What other BS is there other than the one you step on in the cow pasture.
For anyone measuring for wheels and likes things close you need remember a few things about how wheels and made and measured.
For instance on my car I am running an 18 x 10 in the rear with 6.625" back space. Wheels are measured from bead seat to bead seat but back back space is from the back edge. My real overall width is 11" so my true measurment is 6.625" back space and 4.375" front space.
Old Nov 25, 2008 | 06:25 PM
Wouldn't that be CS?
Actually, fans of the movie American Graffiti already know what CS stands for. Just ask Mackenzie Phillips.
(And no, it's not Cutlass Supreme)
Old Nov 25, 2008 | 07:22 PM
I steel having one problem, I couldnt find a 15x10 SS cragar wheels with 0 offset they only have -32 offset. Did you know where to find them?
thanks
Old Nov 25, 2008 | 07:38 PM
car guy
thanks
Crager SS don't come in mutiple offsets. You might have to stick with 15 x 8 to use that wheel
Old Nov 25, 2008 | 07:58 PM
ok Thanks for the help
JpMotorsports
May 15, 2014 07:08 AM
Wildcard
Dec 9, 2012 10:35 AM
69442murph
Mar 14, 2010 10:33 PM
davesdelta
Body work
Oct 14, 2009 12:03 PM
tommyboy65442
Drivetrain/Differentials
Jun 21, 2004 06:48 AM
