Outside Mirror
Old Jul 18, 2008 | 03:12 PM
dynamic88's Avatar
Outside Mirror
does anyone know on the 65 olds dynamic 88 convertable. was there both a LH and RH outside mirror or was there just one on the drivers door. thanks chris
Old Jul 18, 2008 | 03:29 PM
Dapapadon's Avatar
My 66 Jetstar 88 HT only has one on the drivers side. I believe right side mirrors were an option back then.
Don
Old Jul 18, 2008 | 03:45 PM
Don
That's correct. The RH outside mirror was an option. They are rare today. Even as late as my 1984 Custom Cruiser, which only has a LH outside mirror. This car is a complete bottom-of-the-line car, with crank windows, manual bench seat, etc.
Old Jul 18, 2008 | 03:47 PM
dynamic88's Avatar
thanks don, thats what i was thinking. I just finished up a 3yr restro on my 65 dynamic 88 conv. it only had the mirror on the driver's side, but I wanted to make sure I wasn't missing something. Ill have to get one ordered. The original was shot chris
Old Jul 18, 2008 | 03:50 PM
dynamic88's Avatar
thanks joe. i talk to you earlier about my generator light coming on when i put car in reverse. it doesnt come on when i unplugged the switch, but there is no power coming into that wire. i dont know. i took it to a mechanic thats a old car buff. hes doing a few things to it and is going to look at the problem. I tried but gave up. thanks chris
Old Jul 18, 2008 | 04:53 PM
Dapapadon's Avatar
I guess you can take this for what it's worth. I'm just posting it because there may be a connection. Memorial Day weekend I went camping & took the 66 Jetstar 88. That evening we used an inverter connected to the battery & a pump to fill the air mattresses. The next day I had a GEN light. Bright at first, then it dims down. I'm still driving it that way. Although it's mainly dim now. I haven't had any starting or driving problems with it.
But - About only time the light gets bright now is when I put it in reverse! Reverse, light is bright. Park, Neutral, Drive or Low it's dim. Sometimes the light is bright when I first start the car, then it dims as I rev it.
It assumed I damaged the voltage regulator when I used the inverter. Not sure though. But the VR is the first thing I plan to replace. Going to try a solid state one.
Gotta' go, heading out camping again. (Jetstar is staying home)
Don
Old Jul 18, 2008 | 06:39 PM
dynamic88's Avatar
sounds very similar to problem im having. i have a new voltage regulator. ill have to see what mechanic comes up with and let you know. chris
Old Jul 18, 2008 | 09:19 PM
Good news Chris . Check this link to Fusick for your "new" mirror. It's on page 13 of the catalogue.
http://www.fusick.com/catfile/Catalo...Layout%201.pdf
SM6563L Left only Outside
Standard Chrome Mirror.
Includes mounting bracket and
molded plastic gasket.
Fits 1965 All Models.
79.50
Oct 16, 2013 05:35 PM
Centurion
Aug 13, 2012 04:34 PM
junior supercar
Feb 6, 2012 01:39 PM
Gamblin Jones
Jan 31, 2012 10:18 AM
66-3X2 442
Jul 14, 2011 06:28 PM
