How to ID saginaw or Thompson steering linkage on a 65 88
Old Jan 23, 2010 | 07:04 PM
65superrocket's Avatar
What's the quickest way to ID whether you have saginaw or thompson steering linkage on a full size 65'. Thanks.
Old Jan 23, 2010 | 08:14 PM
Run to Rund's Avatar
Saginaw has a flat cap on the joint where the grease zerk is. Thommpson has a stepped or domed cap.
Old Jan 24, 2010 | 08:22 AM
OLD SKL 69's Avatar
GM Enthusiast
My 63 Riviera has an "S" logo next to the zerk fitting on my tie rod ends to denote Saginaw. Clean up the face on your ends and see if you can see the same designation.
Old Jan 24, 2010 | 08:25 AM
wmachine's Avatar
Trying to remember member
Also: measure the pitman arm end centerlink stud at the end of the taper nearest the threads. Sagianw measures .587, TRW .556
Old Jan 24, 2010 | 09:42 AM
Guys, thanks for the advice, I will begin investigating.
Old Jan 24, 2010 | 07:17 PM
rocketraider's Avatar
Oldsdruid
And after nearly 40 years fooling with Oldsmobiles, I still do not understand why they did that...
Old Jan 25, 2010 | 07:09 PM
wmachine's Avatar
Well it was not unusual for GM to use multiple suppliers. But it looked like someone dropped the ball when allowing 2 non-inner-interchangeable systems.
Guess that stood out at the time, but pales by later engineering wonders.
Old Jan 25, 2010 | 07:13 PM
Red Delta's Avatar
Registered Abuser
There is a Safeway style ' S ' on the bottom of my power steering box. Think that means I have a Saginaw on my 66, 88? Or should I still drag my **** underneath and do some measuring?
Old Jan 25, 2010 | 07:45 PM
wmachine's Avatar
I'd trust nothing else. (The S could be for "Steering")
Old Jan 25, 2010 | 07:48 PM
Red Delta's Avatar
Registered Abuser
Good point.
Old Jan 26, 2010 | 07:23 PM
Well, it's Saginaw. Don't know if Saginaw or Thompson is more desirable over the other.
Old Jan 27, 2010 | 03:02 AM
wmachine's Avatar
I've never heard one is any better than the other, and I see no differences that would indicate it either.
Old May 20, 2013 | 09:56 AM
Octania's Avatar
A Saginaw STEERING GEAR can be fitted with either Type T or Type S Pitman arm... so that logo on the STEERING GEAR is moot. You want to look closely at the exact shape of the joints on the center link.
I have all that recorded, somewhere, in the home computer. Might be faster to take new pictures. I hate to go thru a lot of effort anymore because of the ROP crashes where all that good info was lost. We need a backup so that the info stays around.
Also, I am evidently out of town Tu and Wed so it'll be a while now. I do have one of each hanging handy in the garage though. Been there for oh 10-15 yrs now.
Old May 20, 2013 | 03:15 PM
Erinyes's Avatar
Octania, I for one will be fascinated with actual photos of the two types, and am waiting eagerly for your posts.
Old May 21, 2013 | 10:27 AM
wmachine's Avatar
We now *do* have a backup so info stays around. It is called Wild About Cars and the library of the Automobile History Preservation Society.
That is one of the purposes of its existence. To have a place where all of this information can be kept. Where it won't crash and disappear. Where it will be there tomorrow. And will be available to everyone. Now and in the future.
The site is not hosted by anyone else, and not subject to influence or direction of outside forces. There are multiple backups of the information there, and there are provisions to continue the site into the future beyond the lives of those now involved. The site has professional management.
It ain't no ROP, Wmachine Registry, Olds FAQs, or Olds Wiki that have all come and gone.
Old May 21, 2013 | 10:43 AM
D. Yaros's Avatar
As this has been a question of concern for me too, I will contribute what info I have:
Oldsmobile used 2 types of steering linkage in 1961-62..
Saginaw type Tie Rods are Identified by a plastic cover or a metal cover with an "S" stamped into it..
ALTERNATE TYPE (TRW), is identified by a plain metal cover with no "S"
State if steering linkage is Saginaw type or TRW type.
In order to determine type measure the pitman arm end centerlink stud at the end of the taper nearest the threads.
Saginaw measures .587, TRW measures .556.
ALSO, SEE ATTACHMENT:
ros6872
Feb 17, 2015 09:45 AM
ros6872
Nov 19, 2014 09:59 AM
ros6872
Aug 13, 2014 09:50 AM
Joel
Suspension & Handling
Mar 28, 2011 09:30 PM
