package tray braces
package tray braces
hey guys hows it goin. well where to start, my car is a 1971 cutlass "s". the bodyman told me that my car is not fixable because of the rust that the package tray has. i went and bought a package tray (used) and he says that he still cant fix it because theres nothing to weld it to i think he said something about an inner brace or 2 braces that holds the tray to the body. anyone knows what it called??. well i need help tackling it as ill be fixing it on my own i need to know what kind of welder i need and what tools. im going to brace the car cut the tray out with zaw saw, the cut out the braces weld in the donor braces then slide the new tray in spot weld it in place sandblast everything and prime. sounds easy but im prepared for war. thanks for looking
Here are a couple of pages from the parts catalog, those things are one of those things.
http://farm4.static.flickr.com/3573/...2b8dbf6a_b.jpg
http://farm4.static.flickr.com/3462/...5972b7ce_b.jpg
https://classicoldsmobile.com/forums...-replaced.html the brace is in the first pic it goes welded to the inner wheelhouse
Do you have any pictures of the rust in your car that you could share? Man I hate rust, but if you want to save that car it sounds like you have a project ahead of you. How is the rest of the body? Is it only around the rear window area? John
Can you get actual pics of your car damage? Seems fairly straight forward as far as a repair. If it is a 4" section you are talking about, you should be able to even make a patch...what kind of bodyman did you go to?
He says he can't fix it , that's what he gets paid for. Sounds like a parts changer to me...
He says he can't fix it , that's what he gets paid for. Sounds like a parts changer to me...Thread
