Delta 88 brake upgrade parts?
Old Nov 3, 2008 | 09:35 AM
65Delta88's Avatar
I was wondering if there are ungraded brake calipers for a early 80's Delta 88? I am looking for multi-piston calipers mainly then the stock single piston calipers.......
Old Nov 3, 2008 | 09:57 AM
Unless you plan to change the spindle, you're stuck with the stock rotor diameter and sliding caliper interface. Howe racing makes multi-piston aluminum calipers that fit the GM single piston interface and provide a little more piston area. You can also easily upgrade pad material for more friction. Note that a master cylinder with a small piston will provide higher line pressure for a given pedal pressure (but at the expense of longer travel).
Now, if you want to spend some real money, Baer sells a brake upgrade kit for the 94-96 Impala SS that also fits the 77-90 B-body cars. If you currently have a 4.75" bolt circle you will need to convert to the 5 x 5" bolt circle used on the wagons and 98s. Oh, and the Baer kit cost about $4,000...
Old Nov 5, 2008 | 09:30 AM
65Delta88's Avatar
Thanks for the info I will have to check them out
toms1966rgtop
Brakes/Hydraulic Systems
Feb 28, 2010 06:45 AM
Aceshigh
Sep 5, 2009 06:34 AM
toms1966rgtop
Jun 1, 2009 12:17 PM
citcapp
Oct 8, 2008 07:23 AM
citcapp
Sep 18, 2008 08:34 PM
