Master Cylinder bleed before install
Old Aug 2, 2008 | 12:50 PM
68conv455's Avatar
I'm worried I'll drip brake fluid all over the firewall and frame when I install the freshly bled master cylinder. I assume the fluid will be dripping out as I work to re-install the lines. Is this true and does anyone have any suggestions?
Old Aug 2, 2008 | 05:25 PM
Oldsguy's Avatar
Past Administrator
It doesn't leak out that much. I think some judicious use of plastic sheeting and keeping a few clean rags handy to clean up would work. You could go overboard and "mask off the firewall under the master cylinder with some plastic sheeting like the kind painters use, you could also cover the frame below the same way. I don't think the brake fluid should damage the paint if you clean it up quickly.
Old Sep 16, 2008 | 10:49 AM
Kaline's Avatar
Most rebuilt or new master cylinders come with plastic plugs to screw into the brake line connections during installation. When you pull these to install the brake lines, very little drips out. I put a shop rag beneath the master cylinder. No issues.
JCMC64
Brakes/Hydraulic Systems
Jul 22, 2013 09:00 PM
texasred
May 1, 2012 08:48 PM
Bottoms
Oct 7, 2010 03:16 PM
Kidcutty
15
Apr 2, 2010 06:33 PM
84oldsDelta88
Dec 11, 2009 06:19 AM
