New Brake line installed
Old May 24, 2008 | 11:09 AM
Theo's '67's Avatar
HELP! I just installed a new brake line on the front pass wheel....Needless to say my pedal goes all the way to the floor. .. Where is the bleeder valve ?
Old May 24, 2008 | 12:03 PM
If you have drum brakes, the bleeder valves are directly above the inlet for the brake line at the backing plate. You will need to bleed at least the front two wheels.
Old May 24, 2008 | 02:06 PM
Theo's '67's Avatar
I found it as well the other three...I bled all the others except the other front.....My pedal is stiff when the car is off but as soon as I start it the pedal goes soft.
Old May 24, 2008 | 03:35 PM
Oldsmaniac's Avatar
Why would you not bleed the other front?...Because you did not is most likely why the pedal goes to the floor. If you bleed all the brakes properly and there are no leaks and the pedal still goes to the floor the master cylinder is shot.
Old May 26, 2008 | 04:05 AM
Jim's rare 80's Avatar
Jim's rare 80
You only needed to bleed the front. (unless you ran the naster cylinder dry from the brake line.) If you bled the back, then you will have to bleed all four from the start. The procedure is rr,lr,rf,lf. If you still have issues after this, Oldsmaniac is right.
Del70
Dec 7, 2025 02:13 AM
Maverick
Brakes/Hydraulic Systems
Jun 26, 2013 08:21 AM
davepnola
Dec 2, 2010 09:00 PM
Flye
Jul 31, 2009 04:03 PM
68conv455
May 20, 2008 02:03 PM
