53 olds manual to power brake conversion
Old Jul 20, 2007 | 06:30 PM
va88's Avatar
I am wanting to change from manual to power brakes. My mechanical skills are limited but I am ready to get my hands dirty! On my 53 the brake cylinder is under floor board, any advice??
Old Jul 21, 2007 | 08:37 PM
redoldsman's Avatar
Proud Viet Nam Veteran
If you have limited mechanical skills, don't attempt this. A friend of mine has a 54 which I have overseen the restoration. We bought a donor car with power brakes (and steering) to get the parts. We then took both cars to a very good mechanic. Even for him, this was a lot of work. It is complicated by the fact everything is under the floorboard. There is a vacuum canister under the floor that is mounted on the frame. We had to have a new one built. There is a panel on the floorboard around the pedal that is different. I have pretty good mechanical skills and I would not attempt this. It is involves a lot more than getting dirty. The power brakes and steering really do help the car but they are both a lot of work. Just my two cents. Good Luck
Old Jul 22, 2007 | 07:06 AM
ozoneblue's Avatar
I agree with oldsman i have a54 with full power & even rebuilding the system was a pain.If you find a donar car & have alot of time it would be worth it ,& you wont say you have limited skills any more Good luck & keep us informed
Old Jul 29, 2007 | 12:41 PM
va88's Avatar
Thanks for the info! It is great to find things out this way then the hard way.
455Olds
Brakes/Hydraulic Systems
Dec 8, 2013 08:16 PM
KDV
May 27, 2012 08:02 AM
yankees
Dec 2, 2011 02:13 PM
1970442w30post
Jan 20, 2011 05:06 PM
Kahuna
Jun 17, 2007 10:51 AM
