power brake booster question
Old Apr 13, 2009 | 11:32 AM
Vinny72olds's Avatar
Question power brake booster question
Hey fellow olds people,
I would like to know if there is a difference between power brake booster for disc and power brake booster for power drum or are they the same.
Old Apr 14, 2009 | 06:44 AM
Bluevista's Avatar
Registered
In my '68 GTO the booster for front discs is larger in diameter than the drum.
I did a front disc conversion and used the drum booster with a disc MC for years with no problems.
I would assume it's the same with Olds, but we all know what assuming does.
Old Apr 14, 2009 | 09:41 AM
delta88's Avatar
The booster itself should not matter. The proportioning valve is where a lot of the thinking is done in The brake system. Sometimes the master cylinder can change but usually for added capacity of fluid or different ratios of fluid.
Old Apr 16, 2009 | 07:40 AM
Thanks for the help. Vinny
zodiacblueS
Brakes/Hydraulic Systems
44
Oct 12, 2014 03:22 PM
Chumley
Oct 11, 2010 08:25 AM
71supreme
Apr 7, 2010 12:39 PM
iuhoops83
Nov 7, 2008 02:04 PM
