Fuel pump Qs
Old Aug 23, 2008 | 12:23 PM
60Olds98's Avatar
Fuel pump Qs
The fuel pump on my 60 98 394 is acting up.
Anyone know why it would be leaking oil out what looks to be a small vent hole in the pump body, above the bottom diaphragm? There's a square recess in the body facing the right side of the car, and what looks like a vent hole in the back left corner.
I took the pump out this morning to clean it and see what was wrong -- both diaphragms look fine. After I re-installed it, the car started and ran fine for a little while but soon stalled and would only start and stay running with the choke closed. It seems like there's no fuel in the carb body -- the accelerator pump doesn't squirt gas when you open the butterflies.
I pulled the top fuel line connection and cranked the engine -- got some fuel but not what I'd call a lot and not a steady stream. Is this normal?
Could I have installed the pump with the lever in the wrong position? Is the end of the arm supposed to go above or below the eccentric in the case? I made sure the ignition rotor was pointed toward the rear of the car when I pulled the pump, as instructed by the previous owner.
Service manual is on the way, so fewer questions soon.
Many thanks in advance,
Steve
RenderPit
Ninety-Eight
Aug 6, 2015 04:55 PM
mefirst72
Feb 10, 2013 06:37 PM
Nor Cal Andy
Mar 29, 2012 07:27 PM
stlbluesbrother
Mar 21, 2011 03:24 PM
sshriber
Mar 22, 2010 06:16 PM
