water pump 66 toro
Old Aug 2, 2008 | 09:07 PM
geckonz08's Avatar
water pump 66 toro
Can you help please ??
The flange (that the pulley attaches to on the water pump shaft ) I presume that to get this off just use a puller ? Itried this and it hasn`t budged ,yet .OR is my assumption that it is just a force fit incorrect ??
thanks
mike
Old Aug 2, 2008 | 10:22 PM
BILL DEMMER's Avatar
Just the facts...
what exactly are you trying to do here?
the flange is integral to the shaft.
bill
Old Aug 2, 2008 | 10:55 PM
geckonz08's Avatar
hi Bill,
integral to the shaft -oops .Was trying to remove the shaft,check the bearings and clean the fins on the waterpump
cheers
mike
Old Aug 3, 2008 | 11:56 AM
Originally Posted by geckonz08
hi Bill,
cheers
mike
I'm not sure the flange is integral to the shaft (at least not on some versions) but replacement pumps are under USD $30. I'm not sure how hard it is to get one where you are, however.
Old Aug 3, 2008 | 01:02 PM
geckonz08's Avatar
TX JOE,
as there is absolutely no movement in the shaft and it turns smoothly I think I may assume it is ok at this juncture.Will send to the states for another if need be --you guessed it ,not much around here in way of parts.
I am like a kid --gotta pull things apart
cheers
mike
vistacruiser1971
Dec 27, 2012 07:35 AM
Nor Cal Andy
Mar 29, 2012 07:27 PM
72Ctlss
Jun 23, 2009 03:12 PM
SMOKEYMTNKUSTOMS
Jun 21, 2006 04:42 AM
SMOKEYMTNKUSTOMS
Feb 21, 2006 11:16 AM
