thinking of buying big block olds 455..
Old Jun 3, 2008 | 12:01 AM
Oldsprepp's Avatar
now here in sweden we FINNALY got one olds 455 engine for sale!
is supposed to be a 69.
with these numbers..
396021F
Code 39M292223
Nr pipenumber? 9388278
it has not been fired for many years but it turns so its not completly dead :P
is it a good engine to restore or should i look for something else?
should be pushing out more then 300hp ?
it looks like crap here is a pic of it..
Old Jun 3, 2008 | 05:03 AM
Rallye469's Avatar
yep...
that's what it is. '69 455.
What heads? C or E ?
Old Jun 3, 2008 | 07:02 AM
Oldsguy's Avatar
Past Administrator
Considering the scarcity of Olds big blocks over there and the completeness of the engine (looks to have everything except air cleaner) I say buy it. Good luck!
Old Jun 3, 2008 | 08:26 AM
396021F
Code 39M292223
The VIN derivative confirms it's a 69 block. The divorced choke on the intake is also indicative of a late 60s engine. The heads should be "C" heads. The A/C compressor is not a 69 compressor - that would have been the long and heavy A4 compressor. The R6 compressor you have is from a later engine. I've also never seen an idler pulley below the A/C compressor before.
Old Jun 3, 2008 | 11:34 AM
Cranbrook's Avatar
Here in British Columbia there were five 72 , 73 Toronados complete cars. I couldn't get $500 each for them. Four of them just got squashed. I saved mine, the best one and there are 1 or 2 455's cut out sitting on front drive axels that no one seems to want either. Unfortunately , it will take till they are all gone before someone will be wanting them.
Old Jun 3, 2008 | 01:08 PM
oldscsc's Avatar
When you're dealing with big blocks, or rather any Oldsmobiles, torque is king. It is more important than horsepower. Some buick 455's were rated at over 500 ft/lbs. stock. So you might want to put your goals in terms of torque rather than HP since big blocks usually don't turn huge HP numbers.
Old Jun 3, 2008 | 01:24 PM
droptopron's Avatar
delete
That engine with a stock rebuild will be more than 300 HP.
Old Jun 3, 2008 | 11:28 PM
Oldsprepp's Avatar
Thanks for all the good info!
I will try to ****** this baby this weekend..
i can just hope nobody gets his hands on it before me...!
Old Jun 4, 2008 | 11:23 AM
Oldsprepp's Avatar
oh damn sold directly! now i have to wait again...
spiderjason
Dec 1, 2010 11:33 PM
spiderjason
Oct 7, 2010 08:00 PM
64Olds98
Aug 25, 2010 05:19 PM
crumps
Oct 20, 2008 02:12 PM
Nay-Sayer
Aurora
Sep 2, 2008 04:17 PM
