Resurrecting a Totalled Toro
Old May 14, 2008 | 11:30 AM
v8widowmaker's Avatar
inherited a motorcycle trike project about 2 years ago. The person who gave it to me passed away before he could tell me what year or model of Oldsmobile he had used. All I know is that it was an Olds, front wheel drive V8. The engine, I was told is good, so it's worth pursuing. The only numbers I have been able to get from the motor/transmission are the following:
I believe it's a big block, I read that if the width between the valve covers is 14" it's a big block. It's just at 14"
Here are the #'s
409/147 On both sides
7A by #1 (i think #1, it's the front drivers side cylinder)
The transmission had a plate with the following numbers if this helps
Old May 14, 2008 | 11:32 AM
81 AK 7620
Old May 14, 2008 | 11:33 AM
The_Jeremiah's Avatar
7A would be small block heads im pretty sure
Old May 14, 2008 | 02:18 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
If it's a big 7 and a smaller A, the heads are 72 350 heads.
If it's a big 7 and a big A they are Olds 307 heads.
The block casting number will be right by the oil fill tube on top/behind the water pump.
395558 2 would make it a 350.
Old May 14, 2008 | 02:58 PM
409147 is the casting number for the 1972 7A heads. This implies that the motor is also a 1972 350, but who knows.
Octania
Sep 17, 2014 12:23 PM
Olds Dad
Aug 1, 2014 05:12 AM
vistacruiser1971
Dec 27, 2012 07:35 AM
yzzerdd
Jun 15, 2010 09:34 AM
Redog
Sep 13, 2008 08:33 PM
