Oil Pump rod.
Old Mar 3, 2008 | 03:44 PM
mcutlass1969's Avatar
Oil Pump rod.
Well I was pulling my distributor and out came the oil pump rod. I think I have it back in but you never know. So send me suggestions on what you would do. I was thinking of having the rod in and do the engine prime method to make sure i have pressure and everything is working.
Old Mar 3, 2008 | 06:38 PM
If you drop the oil pump drive rod in from the top, and you can see the tip of it at the bottom of the distributor hole, you're fine. Put a 5/16 socket on it and turn it with an electric drill (COUNTERclockwise) and if you get oil pressure, you're done.
Old Mar 3, 2008 | 06:40 PM
Octania
Jul 16, 2015 09:44 AM
widowmaker1201
Dec 2, 2012 01:52 PM
86pontiac
Feb 17, 2010 11:24 AM
mcutlass1969
Jun 26, 2006 05:38 PM
