455 swap
Old Jan 29, 2008 | 02:26 AM
chevyman's Avatar
455 swap
Hi I am in Australia I have the chance to get a 455 Olds engine in need of reconditioning and am going to fit it to my 60 olds in place of the 394 engine. I will be in the U.S.A. in a months time,what I want to know the availability of speed equipment available over there heads ,hi-rise manifolds,headers ,roller rockers ,race cams,comp pistons,the whole works.I will be on the west coast in Califonia Nevada Oregon etc .If any one of you guy,s there can give me some addresses where I can get these parts I would be most greatful cheers and thanks Chevyman
Old Jan 29, 2008 | 07:19 AM
Hipo parts for the 455 are available, but your biggest problem will be the need to fabricate motor mounts for that 1960 frame. The 394 used a front motor mount and rear side mounts on the bellhousing. The 455 is designed for side mounts on the block and a rear mount at the tail of the trans. There is no dedicated swap kit,however others have adapted universal crossmembers.
Old Jan 29, 2008 | 07:40 AM
88 coupe's Avatar
Junior Member
........ some addresses where I can get these parts ........
Dave Smith Engineering
25078 Road 196
Exeter, CA 93221
(559) 562-3500
Bernard Mondello Racing
1520 Commerce St # A
Corona, CA 92880-1766
(951) 371-1432
Norm
TOONLOVESCHERYL
Feb 4, 2016 06:30 AM
Limey
Apr 15, 2013 10:45 AM
'69CutlassVert'
Aug 25, 2011 07:19 AM
Charger1973
Dec 3, 2006 08:43 PM
ricebasher403
Sep 9, 2004 02:23 PM
