57 Olds engine swap
Old Nov 24, 2007 | 11:09 AM
citcapp's Avatar
57 Olds engine swap
I have a 455 ci engine bored 30 over with 10.1 comp. I am going to install it in my 57 olds super 88. I plan on using a TH400 Mondello tranny with this engine. I don't think the two piece driveline will be strong enough for this combo. Should I change to a single piece drive line. Has anyone done this? whats involved?
Old Nov 30, 2007 | 12:26 AM
59-59-59's Avatar
I've done the same thing - only difference is I put a 425 Olds with a long tailshaft TH 400.. The only 'major' thing I had to do with the driveshaft is getting one made the correct lenght and notching only about 3/8 out of the X member frame to clear the U - joint.
Old Nov 30, 2007 | 05:38 AM
Oldsguy's Avatar
Past Administrator
If you observe work trucks, you'll see they use two piece drive shafts, doesn't mean your drive shaft is also strong but just wanted to observe that being a two piece in itself wouldn't mean it was weak or wouldn't handle more torque.
Old Dec 11, 2007 | 10:30 AM
citcapp's Avatar
citcapp
Thanks for the information I am moving ahead with the project full speed
'69CutlassVert'
Aug 25, 2011 07:19 AM
oldsmobum
Jan 14, 2011 10:10 PM
jrok420
Jan 18, 2008 05:18 PM
kayle
Dec 24, 2007 06:03 AM
Retrorocket88
Mar 1, 2007 06:22 AM
