455 nodular crank
Old Jun 23, 2007 | 10:52 AM
VITO's Avatar
Unhappy 455 nodular crank
just picked up a short block with a spun rod bearing i mic's out @ 2.225 on # 8 , on #7 Cyl it mics out 2.250 can this crank be turned or does it need welding then turned
Old Jun 23, 2007 | 11:11 PM
88 coupe's Avatar
Junior Member
How much it can be turned, depends what size bearings your crank grinder can find.
FWIW, all cast Olds cranks are nodular iron.
Norm
Old Jun 24, 2007 | 11:51 AM
GoldOlds's Avatar
Norm
Really?!? I thought only a small percentage were nodular... or is that just for small blocks? I also didn't know an iron crank could be both "cast" and "nodular" at the same time. Guess I've still got some homework to do...
- GoldOlds
Old Jun 25, 2007 | 01:50 AM
88 coupe's Avatar
Junior Member
Originally Posted by GoldOlds
Really? ........
Yes. Really.
........ I thought only a small percentage were nodular ........
Common misconception. Don't believe everything you read on the internet.
........ or is that just for small blocks? ........
Wouldn't all, include 260, 307, 350, and 403?
........ I also didn't know an iron crank could be both "cast" and "nodular" at the same time ........
Nodular iron is the material that was used in all 260 to 455 Olds V8 cast cranks, just as steel was used in all forged cranks.
The legend of the "N" crank, came from the same source that bought us the solid main web 403.
Norm
Old Jun 25, 2007 | 05:48 AM
Oldsguy's Avatar
Past Administrator
Vito, to add to Norm's info I found this link for you from Wikipedia which explains nodular iron. I would add, if they can afford to use it in construction applications like plumbing, it probably isn't too expensive to use in automotive applications as well. As Norm commented, it is just another one of those modern myths.
Old Jun 26, 2007 | 09:11 AM
64Rocket's Avatar
2.250 is NOT 455 OLDS.................................nor is it small bolck OLDS
I thinking it is NOT an OLDS short block..
Geno....
Old Jun 26, 2007 | 09:34 AM
88 coupe's Avatar
Junior Member
Good catch. Maybe I should learn to read the whole post before I reply.
Norm
Bernhard
Nov 24, 2022 09:12 AM
StickW31
Feb 8, 2015 10:52 PM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
cts-v
Mar 9, 2009 09:17 PM
