Q jet Q
Old Nov 11, 2009 | 05:05 AM
Q jet Q
69 442 400 ci, auto, air, q-jet w/ Divorce choke
Is the [I think it's called] "pull off vacuum" [ or vacuum brake] on the passanger side of the front of a Q-jet purppose to prevent the secondaries from fulley opening up at WOT so the engine can "catch up" and won't bog down? Or a smoother "kick in?
Old Nov 11, 2009 | 04:41 PM
442Harv's Avatar
I always thought it was made so you cannot open the secondaries, if the choke is still on? Motor need to warm up first, before you floor it.
Old Nov 11, 2009 | 07:54 PM
sethj78's Avatar
Choke pull off is what its called I think. What r u trying to do?? Adjust the secondaries?? They only open when the motor sucks them open if adjusted right.
Old Nov 11, 2009 | 09:56 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
The vacuum pod attached to the secondaries by that rod prevents the secondary air dams from flapping or bouncing during throttling.
I removed mine and haven't had a problem with flapping, but rumor has it, you pick up a better 60' time if you keep it on, and have the vacuum inlet/outlet size calibrated to your motor.
Old Nov 11, 2009 | 09:57 PM
Correct.
At wide open throttle they are open, but if you immediately let off the gas, the return spring snaps them shut right away.
The vacuum pod helps gradually let the flaps down.
Old Nov 12, 2009 | 05:36 AM
Gotcha
Skitch72
Oct 27, 2013 09:00 AM
oldzy
Aug 29, 2010 09:18 PM
DAN76
Jul 24, 2009 09:01 AM
mpothuizen
Dec 3, 2006 01:40 AM
