ported vacuum switch
Old Oct 28, 2009 | 12:45 AM
1973olds98's Avatar
i have a ported vacuum switch which has 4 air nipples on it..I am putting my engine back together,,,,I have no idea what connect to what,,any help would be appreciated..thanks
Old Oct 28, 2009 | 07:32 AM
rocketraider's Avatar
Oldsdruid
Need to know which engine you have. Vacuum connections are different between 2-barrel, 4-barrel, and stick cars. Assuming you have a 1973 455 by username.
At any rate, a 1973 engine should have a 3-port vacuum switch.
455-4bbl with 3-port switch:
Top port (marked D on OEM switch) goes to distributor vacuum advance.
Middle port (C on OEM switch) connects to ported vacuum on carburetor. It also has a thermal check spark delay valve inline between carb and switch.
Bottom port (MT on OEM switch) connects to intake manifold vacuum tee at front of engine. There is a tee in this line that also directs vacuum to the transmission vacuum modulator.
Most 4-port switches I've seen have a V port. This line connects to the air horn at top rear of carburetor. Under certain conditions the switch will vent vacuum back to the carb. It was routed there instead of to atmosphere to dampen noise. There are two nipples there, one for the choke fresh air supply and the other for the DTVS vent if equipped. If you don't need it, cap it to prevent a vacuum leak if the thing goes silly and tries to vent off vacuum.
The thermal check spark delay valve switches between full and restricted distributor vacuum advance depending on underhood temp. Below 50 degrees ambient it allows full vacuum signal; above 50 degrees it switches to restricted signal to delay vacuum advance. It's strictly an emissions thing and the car will run fine (probably better) without it.
Mongoose
Mar 24, 2014 01:54 PM
Olds luvr
Apr 4, 2011 12:30 PM
esisson
Jun 8, 2008 07:59 PM
dan1s
Feb 18, 2008 11:41 AM
ct1979
Dec 22, 2006 10:22 PM
