c heads
Old Oct 14, 2009 | 07:04 AM
455islove's Avatar
c heads
I was given a set of C heads. they are bear, I was going to put them on craigs list but want to make sure on my list price. is 120 dollars to little or to much? I have some descent G heads but NEED headers as I have 85 307 ones on now. Thanks for your help
Old Oct 14, 2009 | 07:29 AM
70 cutlass s's Avatar
I thinking 30 bucks is all there worth since there bear.
Old Oct 14, 2009 | 01:13 PM
1ATony's Avatar
welcome to the site.
Old Oct 14, 2009 | 03:07 PM
jensenracing77's Avatar
would think they would be worth more than $30 but i don't know. i thought i seen a set of small valve Cs go for $150 a while back. they were cores. if it is a core i would consider it as bare. i am not the expert on this so you will need someone else to give there input also.
Old Oct 14, 2009 | 05:11 PM
citcapp's Avatar
Depends on supply and demand bare heads means someone has to buy valves, springs, retainers, seals, rockers, etc. Complete big valve C heads complete go for around $150.00 to $200.00 in this area. Might be able to get $50.00 for small valve or 75.00 to 100.00 for bare large valve bare heads.
Old Oct 14, 2009 | 06:01 PM
Oldsguy's Avatar
Past Administrator
I agree with Pat. Price them accordingly and to the market. Good luck in selling them though, hoping someone will be able to use them.
Old Oct 14, 2009 | 06:39 PM
455islove's Avatar
Thanks a lot for the help. is anyone running the Edelbrock heads? If so how would you rate them? or even rate them to C heads?
Old Oct 14, 2009 | 06:41 PM
455islove's Avatar
Thanks A1tony its been a lot of help.
Old Oct 15, 2009 | 09:34 AM
citcapp's Avatar
I run the Edelbrock heads on my 455 and like them a lot for the following because I run 10:5.1 compression with no problem on pump gas, the weigh less then steel heads, and run cooler. My heads have been ported as well.
64 CUTLASS KEN
Dec 7, 2020 06:43 AM
olds4life
Dec 25, 2012 12:56 AM
Oldsmaniac
Nov 1, 2010 06:37 PM
gearheads78
Nov 10, 2009 09:31 PM
DarkStar
Oct 21, 2009 07:35 AM
