Oil Pan Leaks
Old Nov 18, 2006 | 10:05 AM
polcatt's Avatar
Oil Pan Leaks
Olds 455 --irritating oil leak near the back of the oil pan...
What is the best gasket to use?
Is it necessary to raise the engine slightly to get the pan off and properly cleaned?
Old Nov 18, 2006 | 12:43 PM
torquemonster's Avatar
You will probably have to take out the motor mount bolts and lift the engine in order to let the front of the pan come down enough to clear the crank. I know this is true of a 455 in a G body, Not sure on earlier vintage ones. As far as which gaskets to use I'm not sure but be absolutely sure you degrease the sealing surface. I would probably reccomend that you use silicone gasket maker at the gasket joints, ie. rubbers at each end where they meet the side gaskets. Make sure you dont have a main seal problem. Olds does make a 2-piece main seal that is easy to install with the crank still in. Good luck
Old Nov 19, 2006 | 01:33 PM
mjscutlass's Avatar
rear seal
if u go to 442.com they tell u about a rear gasket that seals better then the stock one. I think it,s a ford engine gasket u will find it. have fun mike
Redog
Oct 20, 2015 03:29 PM
defiant1
Aug 12, 2014 04:43 PM
StarGeneral
Sep 30, 2012 10:29 AM
TommyT
Sep 28, 2012 05:04 PM
