My Block Sparked?
Old Oct 13, 2009 | 04:10 PM
71cutlass455's Avatar
My Block Sparked?
So I just bought my cutlass on saturday, and trailered it home. I was in the process of checking all my fluids and doing a quick checklist. I went to check my oil, and the little tube the dipstick goes into pulle itself out. When it did that it sparked like all hell was breaking loose, so I quickly unplugged the battery and it stopped. Now I have no lights, and cant even turn over the motor. Did I do some serious damage or is it just a couple blown fuses due to a short in a wire somewhere?
Any help is greatly appreciated, thanks
Old Oct 13, 2009 | 04:38 PM
ent72olds's Avatar
Registered Luser
Sounds like when it came out, it hit the terminals on the starter and maybe crossed or something, causing what happened. Or if it is a 64-67 (A-body I'm assuming you have?) maybe pulling out the dipstick, you hit the junction on the inner fender well that should have a plastic cap over it....sometimes happens to me! Either way, if it was that bad, you maybe melted the positive batt cable to the starter?
Old Oct 13, 2009 | 04:40 PM
Ive got a 71 cutlass, and I have no idea what I hit, i dont remember hitting anything at all lol. Im so confused, I have to take it to a guy to fix it for me
Old Oct 13, 2009 | 05:00 PM
ent72olds's Avatar
Registered Luser
'71...must have hit a bad positive cable near the starter and it arced against the block....
Old Oct 13, 2009 | 05:37 PM
Thats a possibility, thanks, im gonna go check that.
Old Oct 13, 2009 | 05:57 PM
BIGJERR's Avatar
I bleed Oldsmobile
been there done that...........starter postive cable is bare somewere and when you pulled the dickstick and tube it grounded out and more that likely did some melting and welding............
Old Oct 13, 2009 | 06:30 PM
svnt442's Avatar
I wonder if he got too close to the horn relay on the drivers side fender???
Old Oct 13, 2009 | 07:04 PM
Im not sure what I did, but I did some fiddling with the wires, there were a couple exposed that I temporarily wrapped in electrical tape, and it started up fine. There was definitely a negative short somewhere that left me with no power. But its at the shop now and will be fixed BTW the first drive in it was awesome! Lots of power that ive never had in a car. My previous motor was a 350, so a 455 is a big step up
Old Oct 13, 2009 | 11:16 PM
svnt442's Avatar
You may want to look into replacing the harnesses under your hood. It sounds like a huge undertaking, but it's really not. I did mine a few months ago and I can't tell you how happy I am. The two harnesses cost about $325 for the pair. The piece of mind knowing I have new wiring under the hood is priceless.
bocoogto
Aug 26, 2023 06:09 PM
antweave
Apr 22, 2011 11:32 PM
olds4life
Feb 9, 2010 08:48 AM
davepnola
Dec 18, 2009 05:50 AM
NEWOLDSMAN
Nov 17, 2009 12:19 PM
