can a oil pan gasket be changed on a 455
Old Sep 24, 2009 | 10:03 AM
1973olds98's Avatar
without pulling the motor..I was up looking at the bottom end of my motor cleaning it..And it looks like its prob not leakin but cant tell until I start the motor up again...I got everything looking real degreased and clean...It looks like there is room to remove the pan....
Old Sep 25, 2009 | 02:55 AM
Yellowstatue's Avatar
Cool Extrication
The front throws on the crank should be upwards (sideways?) to give you more clearance to remove the pan without binding... its in the chassis manual..
Old Sep 25, 2009 | 07:39 AM
1973olds98's Avatar
thats good to hear...
Old Sep 26, 2009 | 04:48 AM
jims2000lt's Avatar
11.52 @116
You still might have to losen the motor mount and raisw rhw engine.
Old Sep 26, 2009 | 08:51 AM
1973olds98's Avatar
Iam thinkin about pulling the motor and just rebuilding the lower end since i am having the top end done now...There is so much oil all over the bottom of the engine so i beleive i am just going to pull it..That way I can redue the engine compartment,,,clean it up real nice....I love winter projects..
Old Sep 26, 2009 | 09:11 AM
rocketraider's Avatar
Oldsdruid
That will make the job easier in the long run and you'll know what the engine is. Plus it's a great excuse to buy a pressure washer if you don't already own one
Old Sep 26, 2009 | 09:19 AM
1973olds98's Avatar
The problem is i would have to buy a engine puller,,,engine stand,,,engine rebuild kit,,,,,,I have the pressurewasher,,,,lol
Old Sep 26, 2009 | 09:40 AM
You can rent an engine hoist at most rental yards. They have both knock-down and tow-behind versions. You can also rent the engine stand, but you can usually find used ones fairly inexpensively.
Old Sep 26, 2009 | 01:59 PM
1973olds98's Avatar
I found several low cost new engine hoist and engine stands at harbor frieght tools...
MudEye
Apr 22, 2021 06:44 PM
atkinsom
Jan 17, 2013 07:55 PM
TommyT
Sep 28, 2012 05:04 PM
kjr442
Oct 6, 2011 12:41 PM
dallasite21
Jun 20, 2010 05:37 AM
