400 carb?
Old Aug 23, 2009 | 01:00 PM
bullet1's Avatar
400 carb?
just wondering what a good holley carb set up would be for my 68 400.looking at 750 holley vacuum secondarys has a torker intake.not sure what else has been done to motor just picked up car.maybe 750 to large.seems like the quadrajet is too small.pretty sure its not the correct one on it now.
thanks for any info.
Old Aug 23, 2009 | 06:29 PM
The Qjet is already 750 CFM, if the air valve on the secondaries is adjusted properly.
Old Aug 23, 2009 | 07:05 PM
bullet1's Avatar
all qjets 750 cfm?never realized that always thought they were around 600 cfm?i will get numbers off from carb to find out what i have
thanks
Old Aug 23, 2009 | 10:04 PM
Run to Rund's Avatar
Qjets are 750 or 800 cfm. The torker is designed for a spread bore carb, so the jet is a much better choice than a straight line Holley. The Holley spread bores are OK.
chrisneu68olds
Dec 30, 2011 10:17 AM
dgreen
Nov 6, 2011 09:40 AM
Gearhead442
Jan 27, 2011 03:03 AM
sbFALL63
Jan 23, 2011 09:01 AM
sbFALL63
May 28, 2010 05:45 AM
