how much hp and torque
Old May 22, 2009 | 03:57 PM
chris83's Avatar
1968 455 f block punched .40 over making it a 462 i believe.The motor has 10.1 comp trw forged pistons,a comp cams extreme energy 284 duration advertised 286/296/at .50 inch lift 240/246 541/544 lift.Had a new std.crank and clevite bearings.Also had the big valve c heads rebuilt port and polished.The trans is a turbo 350 rebuilt with shift kit and a midwest 3000 to 3200 stall convertor.Thr rear end is a eaton posi 410 and the frame and control arms have been boxed so if any one knows a estimate of the hp and torque would help before she is all back together just in case i need to change something thanks.
Old May 22, 2009 | 08:23 PM
MN71W30's Avatar
It sounds like a great motor. I don't think I would change a thing. I have seen Olds 455's run really strong with less camshaft than you have. When a guy starts talking HP there is alot of room for speculation. A day at the dyno would tell you the real numbers. I saw a simiar Olds engine with head work like yours in a 70 Buick GS run high 11's 20 years ago. The head work may vary the numbers but I would say 450 to 500 HP and probably 500 or more on the torque. I am using the WAG method to determine the numbers. WAG=Wild *** guess.
Old May 23, 2009 | 12:51 PM
Warhead's Avatar
Depending on jetting, ignition curve, unknown porting, baseline 250 cfm heads, unknown exhaust system.....not yet moving, but flashing the converter...I'd say 4700 lbs/ft of torque, in 1st gear-at the tires.
Converter, trans, and axle eats 25% of what it makes, anyway.
Get some aftermarket axles for the 8.5 rear (it IS an 8.5, isn't it?) before you throw sticky tires on it.
ET is the ONLY # that matters, now.
HP is a # for the ego only. Don't worry about that.
JMO,
Jim
Old May 23, 2009 | 03:29 PM
BLUE72RAGTOP's Avatar
Maybe as much as 475-490 HP and above 500 lbs ft of torque with headers, depending on intake, carb, & ignition. You might wish for 1 sz smaller cam since this one will make peak power spinning a little higher than you could comfortably go with this crank. But with all that torque who cares. Should be sweet!
Old May 23, 2009 | 07:27 PM
captjim's Avatar
JMO,
Jim
At 4700 ft.lbs, he will have a tough time sticking the tires!
I agree, ET is the only real number.
Old May 23, 2009 | 09:19 PM
chris83's Avatar
well i was planing on running a performer or cross wind intake i have a custom built holley 850 im running a full msd ignition with msd 6al box and blaster coil and running through a set of hooker headers with three inch pipes back to flowmaster 40s then three inch out the back car weighs about 3500 pounds
Old May 23, 2009 | 09:21 PM
chris83's Avatar
for warhead its a eaton posi unit with 410 gears strange axles and a set of lake wood traction bars
Old May 24, 2009 | 08:25 AM
Warhead's Avatar
4700 in first gear, and I'm stickin' to it.
Good luck, keep us posted, Chris.
Jim
Old May 25, 2009 | 08:08 PM
Brian F's Avatar
My only advice to you is to watch that oil pressure. As I have been told, Olds likes to push all the oil up in the heads and starve the bottom end when you run a low gear like you are. Just watch that oil pressure. I have restrictors in my motor as well as a crank scraper and I run 75-90 on the gauge all the time. Other than that HANG ON SON!
Old May 25, 2009 | 08:46 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Edelbrock Performer intakes run a little better than crosswinds.
The polished crosswind looks cooler, though it's 2 tenths slower in the 1/4 mile.
Old May 26, 2009 | 10:19 AM
chris83's Avatar
thanks j -chic was wondering that info so i will put the performer back on her then
Old May 26, 2009 | 10:09 PM
70Wcars's Avatar
Talking
Wow...bunch of cam!!! Should run well into the 11's with the right tires!! When you run, get an exact weight on your car then use the formula with your known miles per hour at the end of the 1/4 mile to calculate Horsepower.
When ya want to really go fast I'll build you a Q-jet!!
Danny
Oldsragger
Jan 29, 2015 03:51 PM
molasses4masses
Jan 13, 2014 10:04 AM
rtpassini
Drivetrain/Differentials
Jun 11, 2010 12:36 AM
rhurstolds74
Jul 30, 2009 06:43 AM
442 Guatemala
Feb 21, 2008 07:21 PM
