455 timing cover
Old Apr 19, 2009 | 02:51 PM
tim72's Avatar
455 timing cover
I have had two water pumps replaced before this last rebuild. When I got the motor back from the builder he left the water pump for me to attach. Well now I know why the water pumps were replaced twice. The self tapping screws stripped out. Both places who did the work had to know the screws were stripped. Thought about retapping but all the chips would fall inside the new rebuild. I imagine I am not the only one who has had this issue with there water pump screws stripping. The steel thickness is only .125 thick . Of course I had to remove the pan to do this. If the motor was in the car I guess I could have gotten buy without taking the pan off. The two water pumps I got back Ill bet are just fine.
tim72
Old Apr 20, 2009 | 11:17 AM
tim72
One option is to weld nuts to the backside of the timing cover to eliminate the problem forever.
Old Apr 20, 2009 | 07:53 PM
tim72's Avatar
Thanks,
I thought about that.
ketterton
Jun 15, 2015 07:04 PM
jpc647
Jun 10, 2013 11:48 AM
Hairy Olds
Oct 27, 2011 05:35 AM
442scotty
May 13, 2009 05:42 PM
csouth
Jan 21, 2009 09:35 AM
