Dustcover?
Old Aug 23, 2010 | 02:19 PM
Thomas Simcich's Avatar
Dustcover?
There is a part that looks like it covers the ring gear of the clutch assembly, that is missing from my car. Can anyone help me with the name of this piece and where I might be able to find one? It looks as though you can get access to the clutch but also might be some sort of dustcover. Thanks
Old Aug 23, 2010 | 02:31 PM
dc2x4drvr's Avatar
Dust shield..Year One, and several other vendors sell this part..
Old Aug 23, 2010 | 02:47 PM
Going through the Year One online catalog and found a torque converter dust shield, but my car is a manual transmission. Is this the part?
Old Aug 23, 2010 | 03:05 PM
dc2x4drvr's Avatar
I believe so, but it's plastic, originals were metal, contact Brian Trick if originality is important, he might have one.
Old Aug 23, 2010 | 03:11 PM
BlackGold's Avatar
Manuals and automatics used a different cover.
For automatics, it is debatable as to exactly when the switch was made from stamped steel to plastic. I've talked to original owners of 1970 cars, some of whom say they have steel, others plastic.
For manuals, be careful what you buy. I don't know the details, since I don't have a manual trans, but I recall stories about the reproduction cover actually being correct for a different make (maybe Pontiac?) and not fitting an Olds correctly. Hopefully someone else will chime in.
Old Aug 23, 2010 | 09:20 PM
stan 65 cutlass's Avatar
opg has the muncie dust cover, i need one also, they are about $200
Old Aug 24, 2010 | 02:40 AM
Yellowstatue's Avatar
The factory dust cover for a '68 has a full circle of metal that fits around the starter ...later ones had the top of the circle cut off so you don't have to remove the starter to get the shield off ...
Old Aug 24, 2010 | 07:02 AM
Who or what is opg? My car is a 1966 442 with a manual transmission and missing whatever this piece is.
Old Aug 24, 2010 | 07:09 AM
442Harv's Avatar
Origanal Parts Group
Old Aug 24, 2010 | 07:13 AM
dc2x4drvr's Avatar
Original Parts Group. The Parts Place lists a Bell Housing Inspection Cover for $39, probably plastic.
Old Aug 24, 2010 | 07:17 AM
Would the "dustcover" from a Chevelle, GTO, or Gran Sport fit my car?
Old Aug 24, 2010 | 07:39 AM
dc2x4drvr's Avatar
Fusick has a nice repro steel inspection cover for $39..
Old Aug 25, 2010 | 02:14 AM
Only Pontiac would fit because the starter is on the drivers side as opposed to those lesser brands...
Charles Ludwick
Dec 27, 2011 05:49 PM
