Ralley pack with Nightwatch
Old Jul 19, 2010 | 12:19 AM
montvaleplace's Avatar
Question Ralley pack with Nightwatch
I have a 1970 442 without the ralley pack option but with nightwatch(headlamp delay). The nightwatch works through the oil pressure switch and I want to know what happens with a car that has gauges? In the servive manual I only see troubleshooting for cars wiith warning lamps and nightwatch. Basicly I want to put gauges in the car and don't exactly know what to do with the wiring??
Old Jul 19, 2010 | 01:58 AM
scrappie's Avatar
I heard that you were not able to have both options from the factory because the both run of the oil pressure. You had to pick one or the other? Someone please correct me if I'm wrong.
I'm sure where there's a will there's a way to hook em both up though.
Old Jul 19, 2010 | 04:59 AM
Lady72nRob71's Avatar
The nightwatch requires the std oil pressure switch. The gauges need the variable resistance sender.
So in theory, they both cannot be had at the same time. The way around this is to use some sort of brass "T" fitting, where you can thread in both the gauge sender and the idiot light sender.
Such a fitting should be available at plumbing shops. Just make sure the variable sender will clear the intake.
Old Jul 19, 2010 | 06:27 AM
So if I put some sort of Y fitting and both a switch and guage unit I can have the switch wired to the nightwatch and the gauge unit wired to the dash. Sounds simple enough. Thanks...
Old Jul 19, 2010 | 08:09 AM
I think so - I would need to consult the manual to be certain. Not sure where the nightwatch circuity resides and how it is wired.
If there is only one wire to the pressure switch, you will need to run a separate wire from the pressure switch to the nightwatch unit and isolate that from the gauge cluster. It can be done.
Old Jul 21, 2010 | 01:55 PM
Though I could probably make it work, I found a salesmens price guide for 1970 and the two options were not available together. I don't think I'll put the ralley pack I like the nightwatch option anyway. Thanks for the input...
Old Jul 22, 2010 | 05:37 AM
Check to see if you have two wires coming off the pressure switch. If there are two, then wiring will be a cinch - a low brainer. The biggest deal would be getting both senders plumbed.
In 72, there were two wires, one with a big plug going to it. That plug would disconnect and go to the new variable sender. The other would stay on the switch and both would work without any extra wiring.
ThePackRat
Aug 31, 2012 08:20 AM
1980gutlass
Jun 12, 2011 09:50 AM
OldsMotion
Feb 16, 2011 01:32 PM
OldsMotion
Jan 31, 2010 11:58 AM
OldsMotion
Nov 23, 2009 07:07 PM
