442 with a manual tranny
Old Aug 17, 2009 | 08:07 PM
pureplaya442's Avatar
Does anybody know if the shifter coming out of the boot had "442" imprinted on the shaft. i just heard about this, whether or not it's true is beyond me
Old Aug 17, 2009 | 10:36 PM
Ozzie's Avatar
Thumbs up 442 with a manual tranny
The 1965 442 which I have has "Hurst" just below the ball, and "442" further down (in the curve of the shifter).
Old Aug 17, 2009 | 11:31 PM
mugzilla's Avatar
is Fast Enough ...
what year are we talking about here ..?
Old Aug 18, 2009 | 02:11 AM
jensenracing77's Avatar
65, 66, 67. i think that is the only years. i am not sure about 68 but don't think it did.
Old Aug 18, 2009 | 02:50 AM
Nilsson's Avatar
68 has 442 on the shifter.
Old Aug 18, 2009 | 02:59 AM
Yellowstatue's Avatar
Smile Stick it to me
X4 on the '68 shifter...
Old Aug 18, 2009 | 06:09 AM
66400's Avatar
'69 also displayed H and 442.
Henry
Old Aug 18, 2009 | 06:52 AM
wmachine's Avatar
Trying to remember member
Holy cow, guys!
Every year (through '73) except 1964, the stick 442s had "442" on the shifter handle.
Old Aug 18, 2009 | 06:54 AM
wmachine's Avatar
Cool, Ozzie. You must have a 3-speed. What the date on your build? March '65 or later?
Old Aug 18, 2009 | 11:09 AM
I was curious for my 70 442
Old Aug 18, 2009 | 11:56 AM
68Tom's Avatar
Hey Kurt, I'm definitely not questioning your knowledge, but what is this shifter all about? (I also saw an "original" shifter like this on eBay as well.)
Just has the "H"
http://cgi.ebay.com/ebaymotors/1970-...Q5fAccessories
Here's the original
Old Aug 18, 2009 | 12:00 PM
Originally Posted by wmachine
Holy cow, guys!
i have never seen a 70-72 with 442 on the lever.
Old Aug 18, 2009 | 12:24 PM
68Tom's Avatar
So, if our tally is correct it looks like this:
1965: "442" and "Hurst" on the arm
1966: ?
1967-69: "442" and "H" on the arm (with the H lower on the arm than the 442)
1970-72: just an "H" on the arm
Is this correct?
Apparently here's a '67 Hurst shifter.
http://cgi.ebay.com/ebaymotors/1967-...Q5fAccessories
Old Aug 18, 2009 | 12:46 PM
wmachine's Avatar
[/URL]
Don't hesitate to call me out, because if I'm wrong it won't be the first or last time I've been wrong!
I was under the impression that the shifters with only the "H" were non-442 applications in '70-'73 as it was in previous years, but I see that just didn't register with me that they dropped the 442 off the handle in 1970.
Old Aug 18, 2009 | 01:24 PM
My442's Avatar
My 70 442 has the correct #7169 handle, and it says "H".
Old Aug 18, 2009 | 01:26 PM
wmachine's Avatar
1966: ?
Is this correct?
[/URL]
Now that I've extracted my foot from my mouth (leaving more room), in 1965, the only Hurst Shifters were the 3-speeds (with the HD F*rd toploader) option M14, starting in March '65. Those '65 442 3-speed shifters were the only manual shifters that had the whole word "HURST" on the handle.
In '65, the 4-speeds were still Muncie shifters and had only the "442" on handle.
In '66-'69, all 442s (all 3 and 4 speeds) had "442" and the "H" at the bottom, and all non-442s (all 3 and 4 speeds) had just the "H" at the bottom.
Additionally, '66s were square at the top and not tapered.
Old Aug 18, 2009 | 04:09 PM
68Tom's Avatar
Cool. Good info to know. Thanks Kurt.
Old Aug 19, 2009 | 06:17 AM
Ozzie's Avatar
Hi Kurt,
You're absolutely correct. It's the M14 H.D. 3 speed just a few months later from Lansing.
Old Aug 19, 2009 | 07:21 AM
wmachine's Avatar
Hi Kurt,
So you also have a column 2 "B" on your firewall tag?
Pics, please! Love to see one installed on the car!!
Old Aug 19, 2009 | 11:41 AM
Just has the "H"
This is an aftermarket Hurst Competition Plus for a 70-72 with console, as demonstrated by the bolt-on handle. All factory shifters had the snap-in handle.
Old Aug 25, 2009 | 08:12 AM
dan1s's Avatar
Here is a picture of my 68' 442 shifter.
Old Aug 26, 2009 | 03:08 PM
69droptop's Avatar
442 shifter
My 69 442 has a Hurst shifter, but it has the straight handle instead of the curve. It has Hurst on the shifter, but obviously not the 442 and the H. Would it be possible to find the correct shifter handle and bolt it into my shifter?
I'm pretty sure the transmission is original, so somewhere along the way, the shifter got switched out. Any advice is appreciated. Thanks!
Old Aug 27, 2009 | 08:12 PM
yogi442's Avatar
1966: ?
Is this correct?
My 66 has the stock shifter and has "Hurst" and "442" on it.
Old Aug 28, 2009 | 06:52 AM
wmachine's Avatar
We need to talk! PM sent.
Old Aug 29, 2009 | 09:04 AM
wmachine's Avatar
Okay, Yogi and I did some more checking and found that his '66 doesn't have the word "HURST" on the handle.
The word "HURST" on the handle should be '65 3-speed only for Olds.
Old Feb 10, 2010 | 04:07 PM
damascus's Avatar
bringing back a 6 month old post, i know... would some of you factory 4-speed guys mind posting a few photos of your 4-speed console? i have a TH400 in my '71 and am saving my pennies for a Tremec 5-speed. i'm curious if i can get the Tremec shifter to work with my current console or if i'll have to change some things... how similar is the automatic center console to the 4-speed center console?
no worries, purists... it's not an all-original #'s matching car!
Old Feb 10, 2010 | 07:46 PM
For 1970-72 they are the same. The manual trans consoles use an adapter that bolts on top and mounts the shifter boot. The console has score lines on the underside where it needs to be cut out to turn the AT console into an MT console. The MT adapters are available as repros.
Old Feb 11, 2010 | 06:48 AM
damascus's Avatar
thanks! found it at thepartsplaceinc.
Old Feb 11, 2010 | 08:20 AM
vette442's Avatar
Here's what the 4 speed console looks like together. You'll need to cut or replace your woodgrain insert.
By the way, my car had a Richmond manual trans in it weeks before I bought it in 2002 and it worked with the stock console (not so much with the factory floor hump setup though... ) It's back to an M20 now though.
Terry
Old Feb 11, 2010 | 09:10 AM
My442's Avatar
Holy cow, guys!
Wrong.
70-72 have an "H" only.
Old Feb 11, 2010 | 12:31 PM
  #31
Actually, you need to replace it. The AT woodgrain is too short since the AT shifter is further back on the console. Repros are available.
Old Feb 12, 2010 | 05:12 PM
  #32
TK-65's Avatar
Originally Posted by My442
Wrong.
Eh, that was covered about half way thru the thread.
Where did Ozzie go? I want pics of the 3 speed 65!!!!
Old Feb 12, 2010 | 05:28 PM
  #33
todd66442's Avatar
Sound like a rare bar man. Hi RamZ!!!
Old Feb 12, 2010 | 07:18 PM
  #34
damascus's Avatar
more on Tremec 5-speed conversions: i understand that Popular Hot Rodding is doing a magazine piece on a 1965 Olds Cutlass... the PHR Project Car is getting a Tremec manual transmission next. look for the feature sometime this summer.
http://www.popularhotrodding.com/tec...***/index.html
Old Mar 14, 2010 | 06:09 PM
  #35
bummerino's Avatar
66 442 shifter
I went to the garage and pulled out my shifter from my pile of parts....mine has the 442 With the "H"....
Old Mar 14, 2010 | 06:10 PM
  #36
bummerino's Avatar
good thing....
I was a mechanic, I would have starved as a photographer!!!
Old Mar 16, 2010 | 09:32 AM
  #37
Elephant_Engine_Ernie's Avatar
This is an absolutely great thread! Good info and pics!
KidCutlass62
Sep 23, 2014 03:20 PM
Bobac455
Feb 6, 2014 02:04 PM
L69
Jan 5, 2012 01:29 PM
Prophe'c
Apr 16, 2010 08:50 AM
RAMBOW
May 21, 2009 04:56 AM
