thermostat
Old Apr 27, 2009 | 01:11 PM
68Tom's Avatar
thermostat
OK, I'm running a 4-core radiator, 6 blade fan. Between traffic and the (future) Arizona heat, I'm thinking I should run a 180 thermostat. What do you guys think?
Old Apr 27, 2009 | 01:17 PM
csstrux's Avatar
Personally I like them, but that is because I was told in shop class that they are better for performance. I haven't done any research to back that up, but have never had an issue with one that I installed so saw no reason to. As I was told they tend to be a bit more efficient, 195 was used for emissions. Again don't know if it is true or not, never had a reason to confirm.
Old Apr 27, 2009 | 03:45 PM
citcapp's Avatar
I agree the 180 degree stat is they way to go. Keeps the car in its best performance heat range
Old Apr 27, 2009 | 06:39 PM
Lady72nRob71's Avatar
I run 180* Mr Gasket high flow T'stats in every car I have. Best compromise IMHO... Very good temp regulation.
Old Apr 27, 2009 | 09:23 PM
rcorrigan5's Avatar
Randy C.
That's what's in mine and it works great! Randy C.
Old Apr 28, 2009 | 01:48 AM
Bluevista's Avatar
Registered
I had some idling in traffic overheating problems with my Goat (400-TH400) with a 4 core radiator, 180 degree thermostat and the thermo clutch fan (new and working). I switched to a factory flex fan and a 160 degree thermostat and no more problems, stays under 200, not an Olds though. My late mechanic buddy always drilled about an 1/8-3/16" hole in the outer edge of the thermostats, something about letting air out so it doesn't get trapped in the block when filling it. The Vista has a 350, clutch fan and 180 thermo and runs slightly hotter than the goat but doesn't get any worse in traffic, have to see what happens when the AC is working, next project.
Old Apr 28, 2009 | 11:42 AM
68Tom's Avatar
Cool. I picked up a Mr. Gasket 180 High Flow from Summit. Needed to order a spare tire anyway, so figured I might as well grab it.
Old Apr 28, 2009 | 05:10 PM
88 coupe's Avatar
Junior Member
Originally Posted by csstrux
........ 195 was used for emissions ........
Correct. Prior to that, 180° was the industry standard for pressurized systems.
Originally Posted by Bluevista
........ stays under 200 ........
Should stay at, or near, 160° with your 160° stat.
With a well designed, and properly functioning system, one might see your 200° with a 195° stat.
........ not an Olds though ........
Not relevant. Cooling systems are the same.
........ drilled about an 1/8-3/16" hole in the outer edge of the thermostats ........
From what I have read, this little "mod" is worth a 5 to 15 HP increase in Hondas and V6 Buicks.
........ something about letting air out so it doesn't get trapped in the block when filling it ........
By design, air escapes through the bypass system. If holes were needed, they would already be there.
Norm
Old Apr 28, 2009 | 05:22 PM
88 coupe's Avatar
Junior Member
Originally Posted by 68Tom
........ Mr. Gasket 180 High Flow from Summit ........
About 8 bucks, at Autozone.
Norm
projectheaven
Jul 3, 2019 07:16 AM
metro411
Dec 27, 2007 11:10 AM
dynamic88
Sep 5, 2007 10:41 AM
bonesbmx
Aug 5, 2007 01:20 PM
155thINF
Aug 25, 2006 05:30 PM
