What size exhaust?
Old Apr 6, 2009 | 06:40 PM
MN71W30's Avatar
What size exhaust?
I am getting exhaust put on my Olds and the Mechanic is trying to sell me 2.25 head pipes and 2" tail pipes. The engine is a mild 71 455 with a cam. I went from 2" to 2.5" tail pipes on a 454 LS5 Chevelle and picked up at least .3 tenths at the track and a couple miles per hour. I'm thinking 2.25 the whole way, but why not 2.5?
Thanks for any advice.
Dave
Old Apr 7, 2009 | 07:50 AM
citcapp's Avatar
I would go 2.5 all of the way with mandral bends. Sure helped wake up my 455
Old Apr 7, 2009 | 08:08 AM
Eric Anderson's Avatar
x2
Old Apr 7, 2009 | 12:24 PM
MN71W30's Avatar
I kinda thought 2.5 was the way to go. I think the shops like installing smaller pipe to make things easier.
Thanks guys,
Dave
Old Apr 7, 2009 | 01:23 PM
68Tom's Avatar
Hey Dave, just curious what kind of prices you're being quoted to purchase and install your system.
Old Apr 7, 2009 | 01:33 PM
MN71W30's Avatar
I had a local guy that does a nice job quote me $300 for aluminized 2.25 headpipes, 2" tailpipes and mufflers. The price is right. He will allow me $50 because I have my own mufflers.
Dave
Old Apr 7, 2009 | 01:35 PM
68Tom's Avatar
That's pretty cheap. I have a guy in Phoenix quoting me $590. That's with 2.5" pipe and Flowmaster 40s. Guess it's decent.
Old Apr 7, 2009 | 07:24 PM
Cameo White's Avatar
Question
Anyone on here tried the larger diameter repro cast exhaust manifolds that mimic the originals? How about the ovalized 3 inch pipe I see advertised in this area?
Old Apr 8, 2009 | 05:49 AM
wmachine's Avatar
Trying to remember member
Thanks guys,
Dave
Actually that is the stock size, at least in the mid-60s. But 2-1/2s are definitively better from the performance standpoint.
Old Apr 9, 2009 | 08:17 PM
mugzilla's Avatar
is Fast Enough ...
I put a crossover back of the trans and 2 1/2 pipes with stock bends ...
Old Apr 9, 2009 | 08:21 PM
mugzilla's Avatar
is Fast Enough ...
Link ...
plz ...
Old Apr 10, 2009 | 04:58 PM
RAMBOW's Avatar
Ben
Whatever the outlet of your manifolds/headers are is as big as your headpipes should be.
If you have manifolds and the exit is 2.25, it does you no good- (actually probably hurts you) to run bigger headpipes.
If you have headers with a 3" collector or 2.5" collector, then run that size pipe. A lot of racers will cut off a 3" collector and weld on a 12" gradual reducer to go from 3" down to 2.5". (or from 3.5" to 3")
The idea with exhaust is it needs to gradually, and smoothly get smaller- so as to keep exhaust velocity up as it cools down. By the time the exhaust gets to the mufflers its cooled down enough that the size of the tailpipes really doesn't matter. Stock they stepped down one more size in tailpipes, but for performance, you could run the same size as the headpipes, or no tails at all- most performance tests show them to be roughly equal.
Old Apr 10, 2009 | 06:33 PM
Smile Link, as requested
Here is the local company I see all the time at the swaps swelling oversize repro exhaust manifolds and oval pipes:
http://www.ramairrestoration.com
Old Apr 13, 2009 | 10:06 AM
mugzilla's Avatar
is Fast Enough ...
Thanks ...
I'll check out my car for which manifold I have ...
I have a stock set up so velocity may be more important than capacity ...
Guttermouth
Apr 23, 2013 12:38 PM
Wildcard
Dec 9, 2012 10:35 AM
csouth
Sep 16, 2012 08:17 PM
88hurstolds
Aug 7, 2010 10:12 PM
Flye
Jul 3, 2009 01:14 PM
