guam guam guam
Old Jul 23, 2006 | 12:37 AM
help442onguam's Avatar
guam guam guam
i dont know what i have is it a cutlass or 442
help me out heres my information
Year: 1972
Division: Oldsmobile
Series: Cutlass S
Body: Holiday Hardtop (2 door)
Engine: 350 (5.7) V8 2BBL
Plant: Fremont, California
Serial Number: 114774
also need a really good online parts source and any tip for drum beake to disc convertion
Old May 17, 2007 | 11:41 AM
19871442's Avatar
Year: 1972
Series: Cutlass S
I'm only going on the information that you have given here, so I can't get into too much detail without more information, but this will give you more information than you had previously! Although your VIN# on the '72 year won't tell you, if its a 442 or not, you can uncloud some information on your car, so here goes!
Your VIN# should be like this!
The First Digit (3) = (Oldsmobile) Division of G.M.
The Second Digit (should be one of these, F,G, or J) = Model or Series
The Third and Fourth Digits (should be one of these, 57, 77, or 87) = Body Type
The Fifth Digit (should be one of these, H = 5.7 350v8, 2 BC, (160 HP), or J = 5.7 350v8, 2 BC, (175 HP). (J) has Dual Exhaust!
The Sixth Digit (2) = 1972
The Seventh Digit (Z) = Fremont, CA.
The Last Six Digits = Basic Production #s
Give me the Second, Third and Fourth Digits, and I'll be able to break down the VIN most of the way for you! One more thing, if you can get more information on your car, check for the W29 option code, because thats the 442 Appearance & Handling Package. If you have anymore questions that I can answer for you, just let me know!
Old May 17, 2007 | 02:37 PM
As others have said, the 442 became just an option package on the Cutlass models in 1972. I assume this car has the correct 442 grilles, emblems, and boxed rear control arms with rear sway bar? If not, then it isn't a 442, but the presence of the parts doesn't necessarily prove that it IS a 442, because these are all easy bolt-ons.
Old May 17, 2007 | 07:01 PM
OldsMotion's Avatar
OldsMotion
Unless it is a Supreme. 442's were NOT made with the Supreme platform unless it was a convertable.
