Click Here
Wheel alignment or loony bin?
Old September 29th, 2018, 04:05 PM
Chris
Oldssupreme's Avatar
So what's involved with aligning my wheels on my 72 cutlass? Just got it back on all four wheels with all new stock suspension parts and wondering if I should try this myself or am I crazy and should just go straight to the loony bin? Thanks!
chris
Oldssupreme is offline
Old September 29th, 2018, 05:14 PM
Proud Viet Nam Veteran
redoldsman's Avatar
Find a good alignment shop and have it aligned. You really need a machine and know what you are doing. I would try and get the toe in as close as possible before head to the shop so you don't eat your tires up.
redoldsman is offline
Old September 29th, 2018, 05:18 PM
Chris
Yeah. That's what I thought. Right now both wheels are slightly to the right and the drivers wheel is pointing in toward the top. Can I trouble you for a quick and dirty tutorial for adjusting the toe in? Is that the tie adjustment or does adjusting the tie Ross track the wheels left and right?
thanks!
chris
Old September 29th, 2018, 05:20 PM
same but different
don71's Avatar
A guy can get in close in his driveway, but like red says, you'll have to take it to a shop for final adjustment.
How does it look now? Its a nice feeling to finally get it on all fours isn't it?
In the past I've always used the old tie rods as a guide and install the new ones at the same length/turns. Just lay them down together and get them as close as possible. I know, you're already past this point.
don71 is offline
ragz442's Avatar
If you put the shims back in the same spot you removed them from then you can set toe and probably be in the ball park. That's what I did with my last build, it drives straight and doesn't pull. I have access to an alignment rack at work, but haven't got it in yet and the way it drives I'm really not too concerned about it.
ragz442 is offline
Old September 29th, 2018, 05:21 PM
same but different
don71's Avatar
Did you remove andy shims and did you put them back?
I'm not the guy to guide you through this but I'm sure youtube has some videos that can feed your curiosity.
don71 is offline
Old September 29th, 2018, 05:22 PM
72455's Avatar
I dunno if that's a job for the average wrench turner. I took my 72 to get an alignment right after I first bought it, and while they were able to get it close, the mechanic told me I needed more shim adjustment on the control arms. To do this, the control arms have to be removed. From what he told me, it's a pretty labor intensive evolution, and the cost would be $450. And no, it wasn't Tread Quarters...it's a local shop that specializes in older vehicle suspension work and alignment.
So my advice would be to leave this one to the experts😀
Dave
72455 is online now
Old September 29th, 2018, 05:31 PM
ragz442's Avatar
Seems we all replied at once. If the drivers wheel is leaning in than your camber is way negative and you need to get it aligned. Caster/camber needs to be set first then toe. Find a good shop that knows how to align older cars. If there is a shop that specializes in commercial trucks near by they usually will be able to do it right.
ragz442 is offline
Old September 29th, 2018, 05:45 PM
Chris
Thanks for all your replies! I put my phone down for ten minutes to wash dishes and I saw this flurry of messages. (By the way, before you bust my chops about washing dishes, doing that and other light housework in addition to fixing most stuff that goes wrong earns me lots of points with my wife and points equal car time &#128521.
I put new shims in the control arms in the same places and numbers that I took them out as per the photos I took before taking them apart. Unfortunately Im not sure if I got all the thicknesses right but could the wrong thickness make that big of a difference? As for the tie rods, I just made them equal ok either side of the sleeve, probably not how they were originally. So I thought I'd be close but I guess not... I'll take your advice and bring it to a shop. Should be easy to find a place that does commercial trucks. Thanks!
chris
Old September 29th, 2018, 05:52 PM
What? The shims can be inserted after the nuts are loosened. Removing the control arms accomplishes nothing unless they install longer studs, but at that point an offset shaft would be the way to go. I would definitely be asking some questions before letting those fellas work on my car.
Fun71 is online now
Old September 29th, 2018, 06:08 PM
Dave
If that's what they told you then I would find another shop.
oldcutlass is online now
Old September 29th, 2018, 06:22 PM
Chris
One thing that I didn't mention is that since I just dropped the car this afternoon, I haven't torqued down any of the suspension parts yet. I was told that the car should be down and have weight on it before I torque to specs. Could that have anything to do with why it looks so out?
Chris
Old September 29th, 2018, 06:30 PM
72 Olds CS
RetroRanger's Avatar
I think he was saying to get it into spec would require excessive shims and the offset upper control arm cross shaft would be needed.
chris make sure you don't torque the fr and rr upper and lower control arm bolts until the entire car weight is on the suspension.
i just had my 72 aligned based on Eric's prior advice I had the guy give me as much positive caster as he could I ended up at + 2 caster. The original spec is 0 to -2 caster. The positive caster makes the front wheels have a more on center feel. For the camber and toe he followed the original spec. The car drove straight before but on center feel was vague, now the car feels more like a modern vehicle. Other steering improvements I've made are fast ratio box and 1.25" fr and 1" rr sway bars
RetroRanger is offline
Old September 29th, 2018, 06:36 PM
Chris
Retro, ok I'll ask for as much positive caster as possible and leave the rest to specs. And I haven't torqued anything yet. What kind of fast ratio Box do you have? Are there any power steering boxes and pumps from late model cars that would easily bolt in with minimal modifications to get that modern car feel? I do want to get it driving first so I can reexperience what th car feels like with its old fashioned big car steering. It's been a while since I drove it and I'm getting excited to think that I'm getting closer with every mini project I complete. Thanks so much guys!
chris
Old September 29th, 2018, 07:08 PM
same but different
don71's Avatar
Hey, Happy spouse, Happy house. Ain't nothing wrong with doing a few dishes.
If she wants to rebuild the car and mow the grass, I'll do the laundry instead. Its a team effort.
Glad to see the responses to your questions. That means everything is working right.
Rock on!
don71 is offline
Old September 30th, 2018, 04:41 AM
Chris
Don you gave me a good laugh! Thanks! So just to be sure, retro said to be sure to have weight on it before I tighten the upper and lower control arm bolts in the front and rear. But what about the rest of the suspension? I haven't torqued anything down. Should everything else be torqued down before the car is down or should that all be done when the car is down? I'm talking end links, center link, sway bar, etc? Thanks!
chris
Old September 30th, 2018, 05:46 AM
ragz442's Avatar
The center link is part of the steering system and all that should have been torqued before lowering car. The only thing you have to worry about is the control arm bolts that connect the arms to the frame. I'd they are torqued with the suspension hanging you can put the bushings in a bind.
ragz442 is offline
Old September 30th, 2018, 06:02 AM
To clarify, there are three types of front suspension fasteners that need to be torqued with the suspension at ride height. All the rest can be torqued anytime.
Lower control arm to frame bolts
Upper control arm to shaft nuts
Front sway bar bushing brackets to frame bolts
And for completeness, all eight rear suspension bushing bolts must also be torqued at ride height.
joe_padavano is offline
Old September 30th, 2018, 06:19 AM
ragz442's Avatar
Agreed. I just wouldn't be as concerned about the sway bar bushings. I do this for a living and a little lube on the bar where the bushings live (should) do the trick.
ragz442 is offline
Old September 30th, 2018, 06:35 AM
Chris
Ok. So if I'm understanding correctly I can still torque everything down with the car at ride height with no negative implications. Thanks so much guys. I truly appreciate your help!
Chris
Old September 30th, 2018, 07:14 AM
Chris
The only issue would be access to get a torque wrench on all the fasteners. Of course, be sure the tapered studs are properly seated in the mating parts for all the steering linkage. I don't know how loose you left the nuts.
To your original question on DIY alignment, I do my own alignments, however I have turn tables for the front wheels and a caster/camber gauge. It is not difficult if you have the right tools, however there is a non-trivial equipment investment to be made.
Old September 30th, 2018, 07:42 AM
72 Olds CS
I used the rockauto fast ratio box, bolt in replacement that uses the factory hoses and comes w a rag joint about $200
Last edited by RetroRanger; September 30th, 2018 at 12:54 PM. Reason: Friggen autoincorrect
Old September 30th, 2018, 12:34 PM
Chris
So just so I have a good and safe starting point before I get it to the shop, what's the minimum that the tie rods have to be in the sleeve connector? If you look at the picture, both the inner and outer tierods are in the sleeve about the same number of threads. However the drivers wheel obviously need to be adjusted outboard and the passenger onboard to track straight.
Old September 30th, 2018, 01:53 PM
I would get the wheels off the ground using jack stands, center the steering wheel, then adjust so both wheels are pointing forward. Set toe to about 1/8" by measuring the distance between the front edge and rear edge of the wheels with a tape measure.
Fun71 is online now
Old September 30th, 2018, 07:39 PM
same but different
don71's Avatar
Hey, I wanted to wish you continued good luck and point out something that might be obvious. I don't see any grease any where around your ball joints and other zerc fittings. Thats mostly a good thing, but wanted to remind you to give those areas a couple of squirts with grease gun if you haven't all ready.
You don't want those areas too greasy for now, but they'll need some lube if not.
don71 is offline
Old October 1st, 2018, 03:05 PM
Chris
Hi don! You're absolutely right. I haven't greased anything yet. Should I do that before the car is down and everything is torqued or does it not matter? Also is there a brand/grade of grease that you would recommend? Thanks for your well wishes!!
Old October 1st, 2018, 04:31 PM
Grease any time, but if the vehicle is up in the air it may be easier to access the various zerks.
I like synthetic wheel bearing grease, such as Mobil 1.
Fun71 is online now
Old October 1st, 2018, 06:10 PM
Chris
Ok, thank you!
grmchne78
Wheels and Tires
16
October 4th, 2021 08:43 AM
Factoryhotrod
January 2nd, 2019 05:26 PM
kbdecatur
October 18th, 2018 08:38 AM
Bobby455
August 2nd, 2018 05:33 AM
plonka
November 17th, 2013 02:57 PM
Quick Reply: Wheel alignment or loony bin?
