Click Here
Wheel bearing races
Old July 1st, 2018, 06:57 AM
Joe Ralph
72442455's Avatar
Wheel bearing races
I am redoing the brakes on my 72 and the wheel bearings need replacement - bought a new rotor and new inner / outer bearings and grease seal - the bearings came with new races - since the rotors are new do I need to use the new races from the new bearings or are the new races that are with the new rotor fine?
72442455 is offline
Old July 1st, 2018, 07:31 AM
I prefer to use the matched set of races and bearings and would change them out.
oldcutlass is offline
Old July 1st, 2018, 08:16 AM
Yeah, you SHOULD.... but I'll admit that I never have. No problems in over 40 years of doing this.
joe_padavano is online now
Old July 1st, 2018, 08:17 AM
Run to Rund's Avatar
x2 on matching the races. These days, the rotors are probably chinesium and that is OK for the rotors, but I would rather have top quality bearings and races, such as Timkens made in USA.
Run to Rund is offline
Old July 1st, 2018, 08:50 AM
Its hard to find a made in USA bearing, even Timken is going overseas.
Old July 1st, 2018, 09:33 AM
72 Olds CS
RetroRanger's Avatar
I just ordered some timkens the other day I check the coo when they arrive
RetroRanger is offline
Old July 1st, 2018, 01:51 PM
Joe Ralph
72442455's Avatar
i put in the matched races - wasn’t that bad - thanks for the input - regarding the castle nut.... just keep it the same threads in or is there an exact science to it? - my kingdom for banjo bolts though - argh - new calipers - new brake hoses - neither comes with Banjo bolts - tired of trips to the parts store for today - have to walk away from it for now
72442455 is offline
Old July 1st, 2018, 01:55 PM
72 Olds CS
Manual says to tighten castle nut to 30ftlbs while turning rotor, then back off castle nut 1/2 turn, then tighten castle nut finger tight. That is for disc brakes IDK if drum is the same
Old July 1st, 2018, 02:11 PM
Joe Ralph
72442455's Avatar
Thank you! Will do that when I get back to it - appreciate it!
72442455 is offline
Old July 1st, 2018, 03:18 PM
I reuse the banjo bolts but buy new copper gaskets if they didn't come with the brake hoses.
Old July 1st, 2018, 05:23 PM
Joe Ralph
72442455's Avatar
got the copper gaskets - but can’t get banjo bolt out of old caliper - hex is stripping
72442455 is offline
Old July 1st, 2018, 05:56 PM
Napa should sell them.
Old July 2nd, 2018, 03:37 PM
Joe Ralph
72442455's Avatar
got them! I’m going to try something different - I’m going to try and do it correct the first time - I thought I read somewhere to torque banjo bolts down to 22? And does it go 1) caliper 2) copper gasket 3) brake hose 4) other copper gasket 5) banjo bolt? Also - I’ve got the fire wall mount on the other end of the brake hose - does the hose just go directly to the brake line or do I need some gasket or anything?
72442455 is offline
Old July 2nd, 2018, 03:44 PM
Yes.
Have you actually threaded the new banjo bolts into the calipers? I've found that most new brake calipers and wheel cylinders use metric banjo bolts and bleeder screws.
Old July 2nd, 2018, 03:58 PM
Joe Ralph
72442455's Avatar
Yes.
I did actually catch that - I bought new calipers and hoses - I saw (in opgi I believe) that there were two types of banjo bolts available - original and for remanufactuted - so I brought my caliper with me to napa and did it right there - should be good to go - thanks for the input!
72442455 is offline
Old July 2nd, 2018, 08:43 PM
jaunty75's Avatar
See the following 4-minute video, posted in April. He talks about one 20 year old but still new in box Timken bearing that says "Made in Brazil" on the box. He also points out an off-brand part that you would think would be made overseas but actually IS made in the U.S. It's like everything else, now. Stuff can be and is made anywhere in the world.
jaunty75 is online now
Old July 3rd, 2018, 04:14 PM
Joe Ralph
72442455's Avatar
😳 - glad brakes went bad when they did or else I might not have caught this - passenger side outer bearing
front brakes and master cylinder done - just need to do rears and I’m back in action
72442455 is offline
Old July 3rd, 2018, 08:35 PM
People don't even think about inspecting and packing wheel bearings as a periodic maintenance item. Good save, it could have been much worse.
Old July 4th, 2018, 08:17 AM
Joe Ralph
72442455's Avatar
new wheel cylinders are a bit different - old ones had seal pressed into ends - new ones seal wraps around end
72442455 is offline
Old July 4th, 2018, 08:18 AM
They should work fine.
Joe Ralph
72442455's Avatar
the wheel cylinder piston to show “rods” are out too far to reassemble shoes - can I press them in with “c” clamps?
72442455 is offline
Old July 4th, 2018, 08:21 AM
You should not need C clamps to push the wheel cylinder stems back in. Usually the springs will pull everything back in the proper place. Have you turned the adjustment star wheel at the bottom in also?
Old July 4th, 2018, 08:41 AM
Joe Ralph
72442455's Avatar
i did - the star adjuster turns smoorhly - I’m conserned that maybe these new cylinders are too long? - the body appears correct at 3 inches but the rods from the shoes to the wheel cylinders will twist up or down rather then push in the wheel cylinders - wish I took a pick but might redo and show ya - there is a big gap where both shoes meet the guide pin at top - if I pull the rods out of the wheel cylinders they can align correctly - but the rods don’t push in the pistons on wheel cylinders
72442455 is offline
Old July 4th, 2018, 09:54 AM
The pins are held in place with the slots of the brake shoes. Always do one side at a time, so if you get stuck you can look at the other side.
Old July 4th, 2018, 11:32 AM
Joe Ralph
72442455's Avatar
got it all done minus the bleeding - just needed more swearing 😜 - forgot why I hated doing the drum brake “boards” in high school auto class - now I remember - second side was a breeze after I messed up the first side four or five times hehe - thanks for listening - it does help to have someone to bounce it off of
72442455 is offline
Old July 4th, 2018, 11:35 AM
Joe Ralph
72442455's Avatar
72442455 is offline
Old July 4th, 2018, 11:44 AM
Joe Ralph
72442455's Avatar
The pistons like to bind on the back board “forks” (a structure that is in the back plate - no idea on name - it’s more of a raised area) that are on either side of the cylinder - had to loosen the wheel cylinder then push pistons in - that took a bit for me to figure out - then I had to fail at springs several times and run over to the neighbor town to retrieve them - lastly - the washer and the washer with the tube that are the base of the hold down springs matter - I had them backwards first time - the self adjuster won’t function properly if you do this (just hoping someone down the road reads this and learns from my mistake) praying I don’t get leaks - I always do - I’m the worst at liquids - hopefully this works and I’m back on the road again - next project is rear end seals and axle bearings - do you happen to know how many grease zerks a 72 has?
72442455 is offline
Old July 4th, 2018, 11:49 AM
Joe Ralph
72442455's Avatar
72442455 is offline
Old July 4th, 2018, 04:01 PM
Yellowstatue's Avatar
I think you have your shoes on backwards. The long lining shoe goes to rear and the short one doesn't. When you remove those shoes, put a light touch of white grease on the four ? raised patches where the lining rests on the backing plate.
Yellowstatue is offline
Old July 4th, 2018, 05:37 PM
Joe Ralph
72442455's Avatar
argh! Thanks for noticing that! Well I’m getting really good at doing them lol - I put the blue caliper grease on the rub parts of the back plate
72442455 is offline
Old July 4th, 2018, 06:02 PM
  #31
Green car - blue grease?
Old July 5th, 2018, 05:31 AM
  #32
Joe Ralph
72442455's Avatar
red drums - black hood - primer gray spoiler - white interior - she’s a looker! 😜
72442455 is offline
Old July 5th, 2018, 07:36 AM
  #33
Tedd Thompson's Avatar
I knew a guy with a taco wagon just like that!.... Tedd
Tedd Thompson is offline
Old July 5th, 2018, 04:52 PM
  #34
Joe Ralph
72442455's Avatar
Mmmmm! Tacos!
72442455 is offline
Old July 8th, 2018, 07:20 AM
  #35
Joe Ralph
72442455's Avatar
brakes are now 100% thanks for catching the newbie mistake with the flipped pads!
72442455 is offline
Old July 8th, 2018, 07:39 AM
  #36
Sorry I missed that, was looking through the phone. Good catch yellowstate.
Old July 8th, 2018, 09:01 AM
  #37
OLDSter Ralph's Avatar
Please don't take this wrong, not trying to be picky, but those things in the rear are called brake "shoes", not "pads". What YOU have on the front are brake "pads". Some cars were also made with brake "drums" and brake "shoes'
The reason I mention this, is because some cars do have brake "pads" and/or brake "shoes" all the way around. Correct terminology can perhaps avert confusion and getting the wrong parts.
OLDSter Ralph is offline
Old July 8th, 2018, 02:04 PM
  #38
Joe Ralph
72442455's Avatar
mine has both - pads in front (disc) shoes in back (drums) - you are correct - I type faster then I think - sorry about the confusion
72442455 is offline
Brians1
November 1st, 2018 07:07 PM
mitchy
Brakes/Hydraulic Systems
October 5th, 2018 10:11 AM
Stevec
April 16th, 2014 12:18 PM
Jetstar 88
February 17th, 2012 09:55 AM
oldzy
February 19th, 2011 06:23 PM
Quick Reply: Wheel bearing races
