Click Here
14 inch Olds rim 6 inch wide 5 x 5 bolt pattern disc brake
Old January 18th, 2018, 07:35 PM
Tiger69
Tiger69's Avatar
I have looked for a steel 14 Olds steel rim that will accept a hubcap/cover, 6 inch wide, on 5 x 5 bolt pattern, for disc brakes, and I don't find where you can buy a new or used for that matter. Any ideas please? I would probably do any such rim if chromed or not if it can accept a cover. Craig
Tiger69 is offline
Old January 19th, 2018, 07:05 AM
You won't find them because the don't exist. The 5x5" bolt pattern was only used on the full size cars. The optional disk brakes on the 1967-1970 full size cars required special 15" wheels because the rotors are 12" diameter, not the 10.75" diameter rotors used on the A-body cars. The smaller Cutlass rotors allowed the use of 14" wheels. The bigger rotors on the full size cars do not.
joe_padavano is offline
Old January 19th, 2018, 09:11 AM
Tiger69
Tiger69's Avatar
Thank you for the confirmation Joe. Was hoping my research skills were faulty. Was trying to keep 14 inch wheels on a '65 98 as I have new 14 inch OE wheel covers. I thought I would try to put aftermarket calipers on that were not as tall so a 14 inch would fit. I only need 1/2 inch less on caliper height to get a 14 inch wheel on there if I could find a 5 x 5. I assumed the cost of disc brakes was losing the 14's when I did it, but I didn't want to believe it. On to another problem. Thanks.
Tiger69 is offline
Old January 19th, 2018, 05:33 PM
oldspackrat's Avatar
I have 3 or 4 of the 15" 5"x5" wheels that were used on big cars with disc brakes if that helps.
oldspackrat is offline
Mocephus
October 1st, 2021 09:45 AM
Larry DeWalt Jr
Wheels and Tires
November 21st, 2016 09:15 PM
rocketbob54
July 31st, 2016 07:09 PM
Oldsragger
Brakes/Hydraulic Systems
32
June 29th, 2015 01:27 PM
JBrooks
November 11th, 2009 05:04 PM
Quick Reply: 14 inch Olds rim 6 inch wide 5 x 5 bolt pattern disc brake
