14" 87/88 factory aluminum wheels on a 4 wheel drum brake 70S
Out of Line, Everytime😉
Will they fit on the front? I read the 80's 14" SS'III's have different back spacing that hits the A arms on early cars? Assuming these have the same back spacing, running 205/75R14's for the front.
Every single RWD Cutlass from 1964-1988 uses wheels with the same zero offset and the same 5 x 4.75" bolt circle. The difference in backspacing is due to the difference in width - wider wheels have more backspacing for the same offset. In any case, 14x6, 14x7, and 15x7 factory wheels with zero offset will all fit every 1964-1988 Cutlass with factory brakes of any style.
airvegas
December 14th, 2016 10:05 PM
Lady72nRob71
June 27th, 2012 09:08 AM
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
jon69olds
Wheels and Tires
February 11th, 2011 11:57 AM
