1972 Cutlass Supreme Tire Size
Hello, I'm currently running 245/60/R15 tires with the standard 15' rallye wheels. I was thinking about putting some bigger tires in the rear and was wondering whats the biggest tire that I could fit in the rear without modifying anything in the back except for potentially a bigger wheel size.
You can fit some monster sized tires back there, as long as you have the correct wheel backspacing. 295-50-15s fit without any issues (with 5.5"backspacing if I remember correctly - do a search and there should be lots of posts about this) and Brian Trick had some even larger tires on his car.
My V Code '72 Supreme had 305s on it when I bought it in 2002. Scroll down on my website page for a picture of them....
http://highoctaneauto.com/newpage17.htm
Terry
Terry
Not enough info
You can't choose a tire size without a discussion of rear axle ratio. If your car has 2.56 or 2.73 gears & you put a 275 60 15 out back you will HATE it off the line if you have a stock SBO.
What is your rear axle ratio?
Now we need to talk about what is under the hood. If it is a 350 2bbl forget a 28" tall tire. If you have a BBO you can turn the 275 60 15 even with 2.73 gears.
Consider your power output & gear ratio before you pick a tire size.
So it is a 1972 Cutlass Supreme with a stock 350 4 barrel, I am unsure of the rear end, its most likely one of those two, but I have no idea on it specifically. I see your point of the performance issue, can I increase the tire size at all without affecting performance too much or should I just stick with my current 245/60/R15 setup? I just want to give it a more beefy look in the rear like oldschool drag cars. Thanks!
Hello everyone. Once again, I have a quick tire fitment question that I hope the experienced can answer for me. I have a 1971 Cutlass Supreme convertible that I would like to install some different wider tires on the back for much better traction. The wheels that I have are the old vintage American Racing 200S Daisy wheels that measure 15" X 8.5" with a backspacing of 3-3/4". My question is, can I run the Mickey Thompson 3753R Drag Radial tires that are 275/50R15. These tires have a section width of 11.3" and tread width 10.5" and the overall diameter is 26.1". I am worried that the tires might rub on the inside of the rear fender lip. I would like to buy a pair of these for the rear since they are on sale right now and I also need the better traction that the drag radials can offer.
Let me know what you folks think. Will they clear with this backspacing?
#1CutlassSupreme
January 4th, 2009 06:02 PM
