Delmont wheel options?
please feel free to correct any errors, but I have a 67 Delmont convertible and I am looking to go from 14" to 15" rims. if I am correct the current/correct rim for this car is a 14" x 6" wheel with a 5 x 5 bolt pattern and 4,5" back spacing? is that all correct. if so, is there an olds with a 15" x 6 or 7 or even 8" (i guess) that i can look for used to replace these wheels. I AM A BUYER IF ANYONE HAS SOMETHING....
sorry if someone has answered this before, but Isearched and didnt find anything.
also always looking for any OEM Delmont stuff for sale
Thanks,
Mike
Thanks,
Mike
i may have figured this out. again, please let me know if I am wrong.
what I am looking for is a set of 15" rims, 5x5 bolt pattern with 4.5" off set...
seem right?
Mike
seem right?
Mike
you can use rims from at least 71 to 76 delta 88 and 71 to 84 98s.certainly some buick electras an dsurely others.i have some 67 delmont body side moldings and wheel opening moldings.jc
Hollander shows that the 1967 & 1968 Olds 15X6, 5-5 will fit (part number 403898); and the 1962-66 Olds with the 15X6, 5-5 wheels (part number 381950). It looks like you need the 15" optional wheels or the ones used with disc brakes.
The stock wheels were about zero offset. On a 6" wide wheel, zero offset will be about 3.25" to 3.5" backspace. If all you want is a steel wheel that's 15", the stock 15x7 wheels on the 1977-1990 B-body wagons work fine and clear any disc brake swap.
