65 delta wheels
65 delta wheels
Looking for some help on new rims and tires size for my 65 Delta 88. I'm looking at the cragar chrome keystone klassic rims at summit racing. I would like to go as wide as possible and want to give it a little rake look with the rear a little higher than the front. The web site list several bolt patterns,backspace and offsets. Thanks for any help.
Unless you are buying 1960s vintage drum brake-only wheels, any wheel you can buy today will clear factory-size disk brakes. Of course, if you are using an aftermarket kit, it depends on the size of the rotors and calipers.
Ok I have some more info on the two types of rims I would like to go will from Summit both are the Cragars Keystone klassic and the cragars ss supersports.
the keystones are 5x5 8 inch with a 3 and 7/8 back space the 10 inch are 4 and 1/8 back space.
the ss supersports are 5x5 8 inch with a 4 and 1/8 backspace and 10 inch are 4 and 3/4 back space.
I would like to go as wide as I can. any ideas on tire sizes and combinations? Thanks
