1986 cruiser questions
just got an 86 olds wagon for $600. 307 with 200r4. pretty typical. Needs an altenator and battery but other than that it drives great. Couple questions.
Where the heck is the brights switch!! cant find it anywhere
How do i go from the Computer contorolled carb to a normal carb?
anyway to put wood paneling on it? Mine dosent have it and ive always wanted wood wagon.
I wanna put on a hitch. How easy is that and how much can these pull
anyway to make it more efficient/powerful by taking off the emission crap? Ive got plans for headers and cam. Also taking off the Cat converter
any help would be great thanks!
Pull the flasher stalk back for brights.
You don't want to lose the CCC. It's a good thing
Any company that does vinyl wraps can do 'wood' for ya.
Tow rating is upwards of 4000lbs. Get a trailer with brakes tho. The wagon's brakes have enough work to do just reining in it's own weight.
You'll be told ad nauseum that any attempt to get more power out of the 307 is pointless. Step up. All the accessories, and the mounts don't change one little bit when you drop a 350 or 403 in there. Instead of scrapping the cat, replace it with a free flowing one.
That's the 'lights' **** on the dash board. Leave it alone, put your hands back on the wheel, 10 and 2 oclock. Right by your left pinky is the flasher lever. It goes up and down to turn on the right and left flasher ... it also pulls back towards you to turn the high beams on. Pull it again to turn them off. Right below and behind that is a similar but smaller lever, that's for the tilt steering wheel.
I think mixdorf is getting confused by perhaps some Canadian terminology. By "flasher", we U.S.-ers usually mean the 4-way hazard flashers that you used to turn on my pulling a little **** on the steering column but more recently you turn by pushing a button on the dashboard.
What he means is that you want to pull the turn signal stalk (not "flasher lever"--that had me confused for a minute, too) toward you to turn on the high-beams. Push it up to signal a right turn, down to signal a left turn, and pull it toward you to toggle the high-beams on and off.
Brights is usually a british term .. but then the turn signals would be called blinkers.
I deal with 4 languages on a regular basis: British, canuck, american and quebec french. Getting lost in the translation is a frequent thing for me.
No worries. I drove a newly acquired Subaru Loyale 6 hours through the mountains north of QC city in the middle of winter on low beams. When you pulled the stalk back the brights would light, but not stay up. I presumed it was a faulty switch. A week later my hand clipped the stalk wrong and pushed it back and there was that lovely blue light on the dash. It had never occurred to me to push it.
Not faulty at all. This is called the "flash to pass" feature, and it allows you to momentarily flash the high beams to let the guy in front of you know you're going to pass him on a two-lane road. You can also flash an oncoming car at night whose high-beams are on to "ask" him to turn them off.
As for towing, the 200-4R in stock form is marginal without a trailer. I've blown up two with stock, pavement-ripping, 140 HP 307 motors. Get a properly built 200-4R before you even think about towing. Also get a quality trans cooler, as heat will destroy a 200-4R in no time. Bolt-on trailer hitches used to be readily available when these cars were newer, not so much any more. I was fortunate to find one at Carlisle for my Custom Cruiser. You may have to have one custom made. I've also installed AirLift air bags inside the rear coil springs. These are much preferred over air shocks.
It's a tightly integrated system that can be difficult to keep in proper tune but that cannot simply be "ripped" off the engine and still expect the engine to run well or at all. Your best bet is probably to get the factory service manual for this car and learn how to properly adjust and maintain the CCC system.
Or, as the Professur suggests, take the whole engine out and put something in there that predates the CCC and is easier to maintain, like a '70s 350 or 403.
yeah 600 for a well optioned car. 27000 miles. full title and resgistraion. Power everything towing package wire hubcap wheels. ac and heater work. needs some work. Aftermarket radio. Disc brakes squeek powersteering needs fluid and it was almost out of oil when i got it. Dirtiest oil ive ever seen. some small surface rust(really rare here in Iowa) and missing a few interior bit. Anyone know how to fix the headliners in these? I know its a common problem. Also is there an aftermarket partsupplier for B-Bodies? Ebay has a lot of stuff but i was wondering if there was a specialty store.
The CCC system only controls the primary side mixture ratio. The secondaries are purely mechanical, just like those on any other Qjet. The CCC has no effect on WOT performance. It WILL have a dramatic effect on mileage if it is not running correctly, however. Few people have the skill or patience to adjust it properly, unfortunately. You must first ensure that every part of the system is in correct working order (including the miles of vacuum lines) then you MUST follow the adjustment procedure in the CSM exactly.
auto_editor
Vista Cruiser & Wagons
February 22nd, 2011 12:31 PM
PalmSpringsOlds
October 14th, 2010 07:48 AM
