56 front drum
56 front drum
I wanted to change out the left handed thread studs to all right handed. The problem is I have the front hub/drum off and cannot separate them. Aren't they two pieces? I have soaked the hub area and beat on the studs and hub itself with a block to no avail. Does anyone know if this comes apart?
The studs are removed by machining the lip of metal that holds the stud in place. Then they can be removed. Then you need to have the metal pressed back down to keep them tight in the hole. I had to do this on my 57. I understand the right and left threads are a pain and it would be nice to change them out, but in order to get them out, the metal around the stud must be machined to allow it to be pushed out.
Wrong and wrong!! These lug nuts are EASILY found on EBay- in fact Cragar makes a slotted LH wheel nuts in the thread pattern you need 1/2-20. Changing the studs out are a waste of time. Just type in 'LH lug nuts' on EBay
After further searching I have learned that the drum was installed on the hub then the studs were "swedged" to hold the drum to the hub. Sounds like a ton of work to seperate them if you needed a new drum or hub.
455Olds
Brakes/Hydraulic Systems
December 8th, 2013 08:16 PM
Oldssupreme
January 29th, 2013 07:03 PM
1carsick
23
October 2nd, 2012 05:50 PM
