1954 Radiator leak not detectable with air pressure
Old February 3rd, 2014, 08:43 AM
monaco's Avatar
Hello,
I have a problem with the Radiator (brass/cooper) on a 1954 Olds.
This Radiator is leaking under operating temperatures. When I remove the Radiator from the Car and doing a leak test, I can’t see the leaks.
I can just do the test in the cold, place the radiator in a water bath under air pressure (30 psi) and see where the bubbles come out of it. Problem is there are no bubbles and when I but that thing back in the Car, it starts leaking again (loosing antifreeze on a few different places)
Anybody got the same symptoms?
The guy from the Radiator Shop starts to lose his mind, because he can’t detect any leak in the water bath.
What we did already is, I put the Radiator back in the Car, let the Engine run for a few minutes and mark him the pin holes/leaks. Is nearly impossible for the Shop to solder this Radiator without cross checking it. As long it is not hot/warm, the Radiator is tight.
Any suggestions?
Many Thanks!!
monaco is offline
Old February 3rd, 2014, 08:59 AM
Professur's Avatar
Florescent dye ... if coolant is making it out, the dye will mark it. every pinhole in detail. A little puzzled that a professional rad shop needs to be told this.
Professur is offline
Old February 3rd, 2014, 09:16 AM
monaco's Avatar
Well, unfortunately there are not many professional rad shop's in south east bavaria. It seems not even one but Fluorescent dye should be available here as well. Many thanks Professur!
monaco is offline
Old February 3rd, 2014, 10:39 AM
Professur's Avatar
No problem. I chuck a packet in every time I change coolant.
ed burke
Tech Editor's Desk
May 25th, 2015 02:59 PM
fastcutlass1980
April 21st, 2013 01:59 AM
foreverolds
December 1st, 2012 07:07 PM
izaak
June 21st, 2012 03:30 PM
Railguy
Tech Editor's Desk
July 25th, 2010 02:36 PM
Quick Reply: 1954 Radiator leak not detectable with air pressure
