Head bolts or Head Studs
Old May 28th, 2013, 06:26 PM
Olds Scott's Avatar
Since I am missing most of the head bolts from my 324 rebuild should I buys new bolts or switch to a Ross Racing stud kit?
Olds Scott is offline
Old May 28th, 2013, 07:56 PM
Just get new bolts. If you don't plan on racing your car then why would you put racing studs on it? If you were going to put racing studs on it then you "might as well" put a girdle on the bottom end too and...
Olds64 is offline
Old May 29th, 2013, 07:51 AM
Tedd Thompson's Avatar
Ross Racing makes a lot of parts for the first generation Olds motors not all are for racing purposes.That being said I probably would get my bolts at the local fastener store, grade 8 I believe is what was used on the heads ,stay away of the China made stuff if you can ....Tedd
Tedd Thompson is offline
Old May 29th, 2013, 02:37 PM
Ross Racing Engines's Avatar
The clamping force of our studs is far superior that the stock bolts......buying bolts at a hardware store won't be any cheaper than a stud kit....and surely not as good.... That is if you can even find the proper lengths.
I've also got stock bolts if the budget is that strict....give me a call.
Our company name is Ross Racing Engines because of the world we come from ,and the fact that we are custom builders......doesn't mean we don't supply stock or street parts and engines.
Tony
Ross Racing Engines is offline
Old May 29th, 2013, 08:15 PM
XCELERATIONRULES!
Nasty455's Avatar
Not much price difference between buying new bolts and studs.
If you were at 60 over...and the heads were never comimg back off..I might chose bolts.
Nasty455 is offline
stanzaschance
July 28th, 2015 06:38 AM
nolabigdawg
October 25th, 2014 11:50 AM
ttg
November 25th, 2013 06:29 PM
Nasty455
March 30th, 2012 03:16 AM
oldzy
February 11th, 2012 02:30 AM
Quick Reply: Head bolts or Head Studs
