1956 Package Tray Replacement
Old March 26th, 2019, 02:03 PM
tricordati's Avatar
Looking for information on replacing the package tray on my 1956 88 Holiday Coupe? Thanks
tricordati is offline
Old March 26th, 2019, 02:10 PM
TommyTheCat's Avatar
Usually Fusick has some in inventory but it looks like they dont at the moment.
I found this though
https://www.ebay.com/i/173823772254?chn=ps
https://www.ebay.com/i/132977247149?...3D132977247149
hope that helps =)
TommyTheCat is offline
Old March 27th, 2019, 03:31 AM
Frank Ignachuck
ignachuck's Avatar
Two options:
1. Do you have the original package tray? Even if it's in pieces, if you can make a copy of it, Aceshigh provided excellent instructions back in 2011 on how to make your own. I made one back in 2014 for my '56 and it came out great.
https://classicoldsmobile.com/forums...-oer-junk.html
2. If you don't have the original package tray to copy, I traced mine and I can send you a copy (if I can find it.....) Let me know.
ignachuck is offline
Old March 27th, 2019, 06:39 PM
tricordati's Avatar
Thanks. My current package tray is in good shape, it's just the previous owner installed rear speakers and I want to get rid of them. What is involved in the removal and installation of the package tray?
Old March 28th, 2019, 09:47 AM
Frank Ignachuck
ignachuck's Avatar
Well, as I remember, it's very simple.
First you have to remove the speakers.
Then remove the two trim pieces in the corners of the seat back, between the side windows and/or rear doors and the rear window.
Take out the seat bottom. Just lift it up. It pops out. You have to take it out to get at the seat back bolts.
Look for 63 years of neat stuff under the seat!!
Take out the seat back by removing the bolts in the lower outside corners.
The seat back should then come out by lifting up. It hangs on the package tray frame.
The package tray should then slide right out.
Old March 28th, 2019, 12:48 PM
tricordati's Avatar
Thanks. I'll keep the group posted.
steverw
December 31st, 2014 02:22 PM
navvet
December 27th, 2013 10:45 AM
tomc5
November 1st, 2013 08:00 AM
Chumley
February 25th, 2011 02:15 AM
1971olds350
March 17th, 2009 04:26 PM
Quick Reply: 1956 Package Tray Replacement
