1948 Oldsmobile 98 turns over has spark no start
Old March 25th, 2019, 03:46 PM
FuturamicOldsmobile's Avatar
Red face 1948 Oldsmobile 98 turns over has spark no start
Hello all scratching my head with this one. I pulled out my olds straight 8 because it was stuck. I got it freed up and did an overhaul i'm trying to start it for the first time and it does not want to start my timing is correct i have spark and compression what gives?
I have replaced:
points
condensor
coil
Any suggestions appreciated Thank You
FuturamicOldsmobile is offline
Old March 25th, 2019, 05:05 PM
Hookers under Hood
76olds's Avatar
Are you getting fuel past the fuel pump? Could be a bad fuel pump, The fuel filter/carb may be slimmed up a bit since it sat. Is the fuel new ?
Your timing is good and you have spark, so it can only be fuel/air related at this point if it turns over.
76olds is offline
Old March 25th, 2019, 05:27 PM
I don't have the fuel pump hooked up right now i have been putting fuel directly into the carb could it be my cap my spark is orange and there is pitting on my cap terminals inside? Hell i even put fuel directly in the spark plug hole... nothing.
Old March 25th, 2019, 07:40 PM
Hookers under Hood
76olds's Avatar
If your getting spark it should fire up, a weak spark will keep the engine from idling properly. You may have a flooding issue depending on how much fuel your putting down the carb. I wouldn't be putting any fuel down the plug holes lol.
You may want to install a new cap, rotor and set of points when you see pitting.
I'm not familiar with the older engines/point gaps etc, so others will post here to give you a better idea of what course of action would be the best way to go .
Eric
76olds is offline
Old March 25th, 2019, 08:55 PM
Thanks for your reply Eric i will have to do a complete tune up before figuring out what i messed up.
Old March 26th, 2019, 07:04 AM
How are you getting fuel to the carb? Too much fuel will foul the plugs, the engine will not start with very wet plugs. An engine needs Air, fuel, and properly timed spark to start and run. Air is a given generally. Try a blast of starting fluid into the carb before and a short blast during. If it still won't start and the plugs are dry, its ignition.
oldcutlass is online now
Old March 26th, 2019, 08:16 AM
Tedd Thompson's Avatar
Just a shot in the dark but are your battery cables to small? Often 12 volt cables are substituted for 6 volt cables and they will give you grief on startup. You should have something like 2/0 cables for reliable starts, Have you jumped it with a 12 volt battery yet? Tedd
Tedd Thompson is offline
Old March 26th, 2019, 02:44 PM
Hookers under Hood
76olds's Avatar
Your welcome. Sorry I couldn't assist more.
I'm happy to see Eric and Tedd respond, they usually do, these guys know so much more about the older stuff, you'll up and running in no time.
All the best !
Eric
76olds is offline
Old March 26th, 2019, 04:10 PM
Unhappy
Well i did an actual compression test and these are the results
1: 70lbs
2: 45lbs
3: 30lbs
4: 20lbs
5: 20lbs
6: 30lbs
7: 25lbs
8: 55lbs
Not looking good I didn't adjust the valves when i put the flathead back together could that be it i put each solid lifter back in the right hole.
Pistons have NOS rings STD size
Old March 26th, 2019, 06:33 PM
Did you have the carb wide open when doing this test, if not you sometimes get low numbers like these.
Old March 26th, 2019, 08:00 PM
Yes i did, does the automatic choke have to be open?
Old March 27th, 2019, 07:27 AM
Yes
Old March 27th, 2019, 07:52 AM
I would think you would get a pop or two even with those low numbers. It should fire but poorly on 55 lbs. How did the valves look when they were removed, any sign of warp or discolored face. Did you hand lap the valves before you put it back together?.... Tedd
Old March 27th, 2019, 10:10 AM
Valves were hand lapped before reinstall some of the seats had pitting but the were making a seal. I'm going to pull the manifold today and adjust the valves then with the choke open and WOT i will redo the test. If i still have low numbers i will hook up shop air to my compression tester and listen for leaks. I would like to use this engine as i painted it and overhauled it and best of all it's numbers matching I DO NOT want to put a v8 in the car but if it comes to that i will. Thank you all for your replies I will report back once completed.
Old March 27th, 2019, 12:24 PM
'46-98's Avatar
You said the engine was stuck. How long had it been sitting since it was last run? Did you put anything like Mavel Mystery oil in the cylinders and rotated engine over a period of time? Possible stuck rings?
Assuming you have a decent head gasket torqued correctly and valves adjusted properly, have you tried adding a bit of oil in the cylinders to see if that improves the compression?
'46-98 is offline
Old April 2nd, 2019, 08:48 PM
Cutlass Fan's Avatar
Is it possible that you installed the distributor 180 degrees out? If it turns out you don't have compression issues that may be the problem.
Cutlass Fan is offline
Old April 16th, 2019, 11:04 AM
74 2.8L Capri
DFitz's Avatar
Even with the distributor 180 out, it should still pop and fire but back up through the carb.
DFitz is offline
kevin.horton
April 1st, 2017 10:34 PM
Don Roberto
June 14th, 2015 05:51 PM
mauls
May 11th, 2011 01:06 PM
1970_442
August 13th, 2010 09:30 AM
Moofinator
Ninety-Eight
June 4th, 2007 09:02 PM
Quick Reply: 1948 Oldsmobile 98 turns over has spark no start
