Go Back  ClassicOldsmobile.com > Vehicle Lineup > Vintage Oldsmobiles
1932 Olds Info and VIN location >
Old January 17th, 2019, 08:21 AM
I just recently purchased a 32 Oldsmobile coupe off of an aunt and uncle that have owned it since 66. Iím trying to find some more information on it. I received a clean title in their name but I havenít found the vin or serial number on the car anywhere. Thereís a thin metal tag on the firewall with a 3 didgit body number but thatís all Iíve found. Thanks for any help.
Cweber74 is offline
Old January 17th, 2019, 08:49 AM
47 Convertible's Avatar
Some Chevrolets of about the same vintage had an aluminum tag screwed to the floor on the passenger side next to battery box opening. Not sure if other GM cars did the same. Couldn't tell from your photo is your 32 has floorboards in it. Some makes used the number stamped on the engine block as an ID but that looks like a dead end for you if the original engine is gone.
If all else fails your state may have a process for assigning a "VIN".
Is there an identification number printed on the title? If your paper work has some kind of vehicle ID on it, check with vehicle bureau or state police to see if you can stamp the same number on your car and where on the car they specify.
47 Convertible is offline
Old January 17th, 2019, 08:57 AM
No there’s no floor boards either. The tag on the firewall has a body number stamped but it’s just a 3 digit number...197. The vin in my title has a longer number number. It’s a good title so I guess it doesn’t matter too much but if I were to ever get pulled over or need to show a matching number on the car I wouldn’t be able to. Unless there’s something stamped somewhere else.
Cweber74 is offline
Old January 18th, 2019, 12:01 PM
Russ P in MD's Avatar
Here's an old thread where a forum member "blucar" mentioned the location of the tags on a 1936 car, based on info from a reference book he had. Maybe try to contact him and see if he can tell you what the book shows for a 32?
https://classicoldsmobile.com/forums...936-coupe.html
According to this site, it's a plate on the floor front passenger side. See the bottom right VIN/ID section of the form:
http://www.classiccardatabase.com/specs.php?series=284&year=1932&model=15768
If the VIN number on the title has a lot of digits, it may be a replacement VIN number from the DMV. In that case, maybe ask your aunt or uncle if they recall this or have the loose tag?
Russ P in MD is offline
1932oldstwodoor
July 4th, 2018 03:40 PM
johns59super88
August 5th, 2016 03:06 PM
vacabill
April 16th, 2013 07:00 AM
metalmen
August 16th, 2012 02:05 PM
sx455raidercelticfan
August 1st, 2010 08:03 PM
Quick Reply: 1932 Olds Info and VIN location
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
