repair motor
Do you know what the problem is with the engine? Has it been disassembled, if not a compression test should be done and an oil pressure test.
I do not fully understand the question asked. Are you asking what oversize parts are available or are you asking what the clearances (distances) between the bearing and the crankshaft and the distance between pistons and the cylinder wall?
Bonne Chance!!!
Bonne Chance!!!
the problem is in FRANCE when a person owns an American car, he thinks that it has a lot of money, because here to rebuild the engine I am asked $ 15000.
the engine problem it's just a cylinder with no compression
Is it disassembled? Do you know the cause of the no compression? Rings, pistons a valve? What is the compression reading/pressure?
Often this can be repaired without a complete rebuild if the problem can be diagnosed properly.
Forum can guide you well.
Oh no, not again...
Location: Sherwood Park, Alberta, in the Great White North
La meilleure chose à faire est d’obtenir d’eBay un manuel d’entretien Oldsmobile pour le modèle 1949.
Il y a de fortes chances pour que le joint de culasse soit défaillant ou la soupape d'échappement.
Aucun autre moteur ne tient facilement dans cette carrosserie, à l'exception d'un moteur V-8 Oldsmobile; toutes les autres nécessiteraient beaucoup de modifications de cadre.
tva442
May 27th, 2019 06:06 PM
