Suggestions for '46 98 Coupe Trunk Support Rod
Old November 16th, 2018, 05:34 AM
'46-98's Avatar
My car is missing the lift support rod on the trunk lid. Very unlikely, but does anyone have a spare for an '46 98 Custom Coupe?
Any idea if a modern gas strut would handle the weight of the trunk lid?
I was thinking I will probably have to make a locking dog leg arm.
'46-98 is offline
Old November 16th, 2018, 05:40 PM
Oldsdruid
rocketraider's Avatar
A pair of struts might. Check some streetrod and Chevy forums and parts suppliers since most GM from that timeframe used that lock rod.
rocketraider is online now
Old November 16th, 2018, 08:01 PM
Oh no, not again...
Nailheadcanuck's Avatar
Location: Sherwood Park, Alberta, in the Great White North
That rod is exactly the same in a Buick from 1942 to 1948.
Another option if you want something more modern is a gas filled cylinder off of a modern hatchback or SUV.
Nailheadcanuck is offline
Old November 16th, 2018, 08:31 PM
FuturamicOldsmobile's Avatar
Hydraulic ram like gene Winfield
FuturamicOldsmobile is offline
Old November 16th, 2018, 09:20 PM
If you know the weight of the lid contact one of the strut manufacturers and they can make a suggestion on what to supply you with.
1969w3155 is offline
Old November 17th, 2018, 05:32 AM
'46-98's Avatar
Thanks for all the suggestions. I like the original lock rod style, I have the same kind on my '38 Dodge and they work great. I will continue searching for a possible GM match.
'46-98 is offline
Old November 17th, 2018, 06:07 PM
Sporty45's Avatar
Would something like this work?
https://www.ebay.com/itm/1946-47-48-...4383.l4275.c10
Sporty45 is offline
Old November 17th, 2018, 06:12 PM
Sporty45's Avatar
Or this,
https://www.ebay.com/itm/ORIGINAL-TR...el!03825!US!-1
Sporty45 is offline
Old November 18th, 2018, 04:46 AM
'46-98's Avatar
Dennis, thank you very much for your research. You did much better than me on Ebay, both supports look promising. The NOS unit looks extremely close to the correct dimensions, but possibly a little long.
The one for the Buick, hopefully a Sedanette, looks like this model has the exact truck lid as my 98. I will contact seller for open and closed lengths.
Does anyone have the cross reference for the Chev 4114965 part number listed as a support?
'46-98 is offline
Old November 18th, 2018, 06:26 AM
Sporty45's Avatar
No problem, I enjoy the research! Good luck.
Sporty45 is offline
Old November 25th, 2018, 04:56 PM
47 Convertible's Avatar
Olds Trunk Rod style and length
Nick, trunk support rod on my 68 series convertible is 28 inches open and 16.5 closed. A couple of photos attached.
47 Convertible is offline
Old November 26th, 2018, 05:42 AM
'46-98's Avatar
Jerry,
Thank you for the measurements and photos. I have heard back from both sellers on Ebay and yours and the 2 others are basically the same open and closed lengths. As you suggested it would probably best to go with the C body Buick one.
Thanks again for your assistance.
'46-98 is offline
Old December 1st, 2018, 10:11 AM
'46-98's Avatar
Thanks again for the help
Ended up buying the 46' Buick one that Dennis found on E-Bay. Cleaner her up, painted it and installed. Has to be the same unit as the original, as it works perfectly
'46-98 is offline
Old December 1st, 2018, 10:18 AM
Sporty45's Avatar
Happy I could help, and glad it worked!
Sporty45 is offline
Old December 1st, 2018, 06:42 PM
re. book you are looking to buy
Dennis, somehow lost your PM on the manual you need. I did look at mine and it is different and not as specific. Buy the one you had put a link to.in the PM
Jerry
Old December 2nd, 2018, 04:08 AM
Sporty45's Avatar
Jerry
Done!
Sporty45 is offline
TheBigBlueBoat
Body work
March 26th, 2019 06:59 AM
Joah_from_Alberta
October 4th, 2016 02:19 PM
cfair
April 4th, 2014 07:27 AM
L69
October 14th, 2013 03:50 AM
Allan R
November 20th, 2009 08:54 PM
Quick Reply: Suggestions for '46 98 Coupe Trunk Support Rod
